Torn rubber door gasket
tshrop
Ted
WA
This is for everyone’s information. I have a 2019 Ranger with about 22000 miles on it. The attached photo shows damage to the driver door rubber door gasket. This truck lives a pampered life: no off-roading and not a work truck. An easy fix but the dealer is claiming it’s not under warranty. We’ll see.
OFC Ranger
Jack
ZR2
Ok you need to figure out what the heck is rubbing that when you get in and out.
That clearly shows a pattern.
Kind of like the seats on our patrol cars on the lower back side supports where our radios or other various holstered items eventually shred the cloth.
Not be rude, are you a big fella?
Joeiconic
Looks like a about a two foot area where something is regularly wearing on that area. Unless you can prove it’s the door rubbing, which seems unlikely, that’s probably not a warranty fix.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
It puts the lotion on the gasket.....
IT PUTS THE LOTION ON THE GASKET!!!!
OFC Ranger
Jack
ZR2
So here are the high wear areas on patrol car it really doesn't matter if you're fat or skinny it's pretty much going to be the same. The first two pictures showed the door seal area same as on your truck and the other area is where the gun holster is and then our backs
Now I could be incorrect but if you look at my door seall markings and yours the wear is similar enough that if I was a betting man you've rubbed it that way somehow
