Tonneau Cover for 2023 Ranger Lariat
Mat240
New Hampshire
2023 Ranger Lariat
Business Owner
Has anyone run into this issue? The 2023 Ranger bed side rails and tailgate top are higher than the bed rail at the cab. By well over an inch. So there is a large gap because the tonneau gasket doesn’t sit on the lower cab rail section. Am I missing something here? Got the Gator hard cover Tri-fold which says it fits the 23. The gasket is built in. Doesn’t come close. Of course this will allow water in.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
it is normal, although odd design choice. That part of the bed is called the bulkhead.
I used 1" open cell foam for my application, but I suggest you use 3/4" closed cell foam seal, and double them up.
https://www.amazon.com/gp/product/B07RXWQ2T7
Works well.
Muscleford
George
Ohio north coast
Retired CFO
Not that way on 2021 Lariat. I had no issues with my tonno fitting
Mat240
Mat240
New Hampshire
2023 Ranger Lariat
Business Owner
Works well.
Thanks. Exactly what I looked at today at Home Depot. Shouldn’t have to though. If that’s the way the 23s are Tonneau companies should be including a thicker gasket on the bulkhead end.
Stevedbvik1
2022 Ranger Tremor XLT
My 22 Tremor is that way. Had purchased a Gator soft tri fold and it came with the proper foam seal. Then went with the Truxedo LoPro soft roll up and that also had the proper foam seal.
Stevedbvik1
Here’s the instructions that came with the Gator soft trifold. Along with the extra foam seal
Mat240
Mat240
New Hampshire
2023 Ranger Lariat
Business Owner
Ok, this is what they needed in the hard fold too! Now I gotta call em. Thanks!
gtyates
Greg
Ranger, Explorer, Sport Trac
Manager
I would suggest purchasing a tailgate seal kit. You will need this anyway to keep road spray from making its way in the bed around the adges of teh tailgate. There will be extra sealing material that you can use to fill in the gaps at the bulkhead. I had to do the same.
NoTacos
Peter
Vancouver BC
2021 RangerXLT CrewCab 4x4
I don’t have a Gator hard cover but have a Bakflip MX4. The one seal it came with was too short to use with the drop in liner and the seal for a bed with no liner was too thick. So I got some 3/4” rubber gasket the truck accessory shop used for installing canopies and it was the perfect fit for that gap. Just my experience.
Mat240
Mat240
New Hampshire
2023 Ranger Lariat
Business Owner
