Those who did a Battery change?
HeavyDuty
Kevin
East of Nashville
2021 Lariat, FOX 2.0 (set at 2"), 275 65 R18
Builder, Restorer
When you switched out your battery did you lose any or all of your settings?
JesseS
Jesse
NorCal (Roseville)
Use a 'Memory saver' 12v source to keep power on the system while changing the battery. I have a small Lithium battery that works well, doesn't require a heavy cable.
HeavyDuty
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
Great Idea!
Todd Chapin
Todd
Alexandria
2019 crewcab lariat fx4
Chef
Will be replacing mine soon with an Interstate. Ford OEM batteries suck and cannot be relied on past 36 months as I have learned through my previous 4 Mustangs. I more worried about all the fuses and crap attached to the battery than losing memory.
oldnslow
Ken
Sahuarita, AZ
2020 Ranger XLT FX4 SuperCab Rapid Red
I changed mine out last spring (less than 2 years old) and I believe I did lose some settings. I just went through everything after the install and a few things had to be set again.
HeavyDuty
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
Ok thanks.
I go up in the mountains to work on these 3 log cabins and I'm changing battery to an Odessey to use with an inverter for tools. Keeping OEM battery for back off. I was going to get a Yellow Top Optima but was having a tough time locating one.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
When I disconnected my battery, I lost the window settings and the audio, Bass Treble settings but not the station memory presets. Maybe the time settings too.
HeavyDuty
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
This is suppose to be reliable. Being off grid and alone in the mountains on some of these trips - I certainly don't want my battery to give me trouble.
NeilP
Neil
Spearfish, South Dakota
RETIRED!
I have a set of Odyssey batteries in my 2000 F250 diesel. I installed them in 2010 and they are still going strong! Just my opinion, but they are worth every penny.
HeavyDuty
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
Have one in my 2007 E 250 and going strong too. About 4 years on it.
Grandaccess
Binghamton, N.Y
Computer Consultant
I am still having good luck with the stock AGM so I will just leave it for now, but sooner or later will switch it out for a larger stronger battery, I normally have a lot of crap plugged in because I am a Ham Radio Operator, if I PTT on my Icom I can Dim the lights LOL
I will look for a stronger AGM from now
find all the lose wires under your hood and tie them all together, that should give an extra 10 HP?
I replaced my dead battery a week ago...lost the driver auto up/down window mode...don't know what else was lost...
