Telematics Control Unit (TCU) Location - "FordPass Connect Modem"
rangerdanger
SF Bay Area
The Telematics Control Unit (TCU) is located behind the passenger seat glovebox.
Vehicle Wi-Fi Hotspot (if equipped)
The TCU provides the vehicle Wi-Fi access point.
The TCU communicates to the cellular network by two means. The primary connection is through the cable to the cellular antenna incorporated into the GPS/Satellite antenna. The secondary means is through the cable to the TCU antenna.
Does anyone want to remove the glovebox to see if they can see it?
From 415-00B Information and Entertainment System - Sync 3, page 3 of 15 from Description and Operation - Component Location manual.
415-00B Information and Entertainment System SYNC3 Description and Operation Component Location.webp
Pinecrestjim
Pinecrest, FL
Well, that answers some questions! The communications is thru WiFi and cellular (has to be GSM if they are referring to obtaining an account thru AT&T), with an antenna located somewhere above or behind the instrument cluster. It does not use the roof mounted antenna.
rangerdanger
rangerdanger
SF Bay Area
It actually uses the GPS antenna along side the dashboard antenna. It has dual antennas for redundancy.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Revival on this thread: I was under the dash/glovebox out and noticed my TCU (#4 in the diagram above) didn't utilize all the connectors on it (left of the red connector in this pic). Wonder what else there is?
underwhelmed
GSMs
Retired Military
Reviving. Did you ever disconnect the module? If so did it cause any issues. I’m tired of all this spyware in modern vehicles and want to disconnect it. Then I’ll drop it off with local Ford dealer…
seasprite
Missouri
2022 Ranger XL STX
Racket
Here and There
Transient
I haven't messed with it and haven't looked further into what the unused connectors might be for.
underwhelmed
GSMs
Retired Military
