Telematics Control Unit (TCU) Location - "FordPass Connect Modem"
rangerdanger
SF Bay Area
The Telematics Control Unit (TCU) is located behind the passenger seat glovebox.
Vehicle Wi-Fi Hotspot (if equipped)
The TCU provides the vehicle Wi-Fi access point.
The TCU communicates to the cellular network by two means. The primary connection is through the cable to the cellular antenna incorporated into the GPS/Satellite antenna. The secondary means is through the cable to the TCU antenna.
Does anyone want to remove the glovebox to see if they can see it?
From 415-00B Information and Entertainment System - Sync 3, page 3 of 15 from Description and Operation - Component Location manual.
415-00B Information and Entertainment System SYNC3 Description and Operation Component Location.png
Pinecrestjim
Pinecrest, FL
2019 Ranger, 2018 F-150, 2016 Escape
Well, that answers some questions! The communications is thru WiFi and cellular (has to be GSM if they are referring to obtaining an account thru AT&T), with an antenna located somewhere above or behind the instrument cluster. It does not use the roof mounted antenna.
rangerdanger
rangerdanger
SF Bay Area
It actually uses the GPS antenna along side the dashboard antenna. It has dual antennas for redundancy.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Revival on this thread: I was under the dash/glovebox out and noticed my TCU (#4 in the diagram above) didn't utilize all the connectors on it (left of the red connector in this pic). Wonder what else there is?
