Tailgate question
JimH
Palm Coast, FL
When my tailgate is down, the right side cable is tight, but the left one is loose. If I apply pressure to the left side of the tailgate, the cable gets tight. Does anybody else have this problem? Or is my tailgate warped? Or ???
Don't worry this is common. Tolerance on cables not great, the aluminum tailgate will flex some also. If you swap cables side to side it may shift it or not.
SILK
Ty
Eastern Pennsylvania
2019 XLT Crew Cab Sport, 2018 Santa Cruz Tallboy
IT Director
The best fix for this is a tailgate damper. Just ask @AzScorpion
NickTheEnforcer
Anthony
Northern Illinois
More importantly my dealer service advisor put low-profile lisc plate screws on my truck and showed me that with the gate fully open/down the bottom edge pushes against the plate, screws and 'bows' the plastic fascia...poor engineering detail with no expected fix! He said that he has been addressing as they come in to prevent problems, paint coming off when taller profile self-tapper/hex heads are used.
But if he adds a damper then he has to start modding that too. It's a vicious never ending cycle! :crazy:?
JimH
JimH
Palm Coast, FL
I already have the damper. I disconnected it and found it will extend another 4 or 5 inches, so that's not the problem (or the solution).. :shock:
RangerDangerStranger
SF Bay Area
2022 Nissan Frontier SV in Tactical Green Metallic
Cool Dude
The problem is that your tailgates become weak and punny, and not able to open all the way! A common side effect of dampers.
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Just checking in to make sure Dave covered the damper already since tailgate was mentioned. ?
A little late cuz I was working but I'm on it. ?
FoD
Terry
Out There
Retired & Grandparenting 🤣
Best bet is to open tailgate and while time delay gravity defying time slip flux damper is doing it's thing, jump into truck, slam into reverse, floor it and back into a power pole at speed. Should be enough to make the necessary hinge adjustment that tightens up the wayward cable :idea:
THLONE
Thom
Tucson,AZ
internet wise guy
Just another thing for dam per people to do while waiting for their tailgate to open. In order to do a truly scientific test you must watch your tailgate come down many many times. ?
shirleyb
Spokane Washington
2019 Ranger, Shelby GT-500, Edge
shirleyb
Spokane Washington
Here is my solution:
Every F-150 I have checked have one cable loose. They should have an adjustment, but do not.
Rangers also have this issue. My solution:
Remove the tight cable and use a hight speed grinder with a small bit. Remove a very small amount of material and reinstall and check if it is tight like the other side. You could even use a small rat tail file to remove material.
I worked perfect for me, I do not think the tailgate is warped, the Ranger should have an adjustment, but none do.
Thanks, Shirley
