- First Name
- Phil
- Joined
- Apr 3, 2019
- Threads
- 149
- Messages
- 7,085
- Reaction score
- 37,253
- Location
- GV Arizona
- Vehicle(s)
- 2019 Ranger FX4 Lariat 4x4, 2020 Lincoln Nautilus, 2005 Alfa Motorhome
- Occupation
- Engineer Retired
- Vehicle Showcase
- 1
Hi Terra,@HotShotOffroad normally, I'd tend to disagree with the idea that adding a rear anti-roll bar would REDUCE oversteer, but for some reason I can't help but entertain this thought.
Maybe one way a rear anti-roll bar would help this situation the OP mentions is if the skitteryness and "stepping out" is caused by an axle tramp (the left and right sides hopping out of phase relative to one another) resonance. The rear ARB would only help if the shift in "tramp resonant frequency" is enough to keep it well higher than the "input frequency" of the washboards AND the shift in roll stiffness bias isn't enough to make the truck an oversteery handful. I suppose the soft inboard mounted dampers aren't really helping to damp axle tramp, either...
But... I'm wrong a lot. @P. A. Schilke how does that grab you?
Either way, running dirt roads in 4hi or going slower or faster might be easier to try before OP gets out the parts cannon. (don't get me wrong, I love screwing with thoughtfully engineered stuff)
Okay...the end of the vehicle with the suspension with the stiffest rate in roll generates the highest slip angles meaning tires slip at a greater angle than the tire is pointed. So, a rear bar will cause the rear to kick out at a increased angle from a non rear bar truck. There is a metric called roll stiffness balance between front and rear and if you change just rear, that changes the balance. Most people like Understeer as it is comforting to them...Oversteer is not... ie back end out in a turn dynamic.
Now...this only occurs in a turn where there is a twist in the suspension between inside tires and outside tires/suspension. Straight up and down...bars have little to no effect. Twist the truck and bars come into play for vehicle dynamics....
You are correct about inboard shocks...and this was the bugger for prior generations of Rangers that were prone to skate/dart.... The damping of the shocks was minimal due to what we call motion ratio...the amount of shock travel up or down relative to the wheel....more inboard the shocks the less effective they are in roll. So tune for roll and the damping up and down is worse, so you have to compromise in straight up and down vs roll where one wheel is up and one down... Since Shocks are velocity devices, there are opportunites with sophisticated valving, to a degree. This is where $ enters the equasion for the cost benefit ratio and most folks will never press a truck to its limit...so soft controlled ride is the objective. FX4 is tuned for offroad and unfortunately folks call it bouncy for on road in some cases. It is doing its job, JMO, but off road more than on road. Add a rear bar, and aftermarket shocks might not be the ticket for tuning..
Welcome to the world of vehicle dynamics.... tuning this trade off. I am a proponent of Big Bars and soft springs.
Okay....Retreating to the flameproof bunker.... let the pundits pontificate....
