Super cab owners
kpgreenwell
Kenny
Kentucky
2017 Camaro 2021 Lincoln Corsair 2022 Ford Ranger
Electronic Technician
Are any Super cab owners having issues with the bed aligning with the cab on the sides? My new Super cab the cab on the passenger side is about a 1/2 inch wider than my bed. The driver side is perfect
My 2021 is perfect...
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
Wow, that would suck to have to take it back to the dealer or body shop to get it aligned. But I would bring it up now if you can't live with it...
Muscleford
George
Ohio north coast
Retired CFO
Mine is perfect.
Probably just a matter of loosening the bed bolts and tapping the drivers side bed with a 3 lb sledge hammer to move it the 1/4 inch necessary.
It may have been done intentionally to put more weight on the drivers side to get rid of the dreaded "lean"
kpgreenwell
kpgreenwell
Kenny
Kentucky
I did bring it up and took it to the dealers body shop and they were going to align the bed . But when I took it in they said it could not be aligned. I am not believing that so I will take it to my body man and get his opinion. If you look down the side of the bed from the rear to the cab you can see it. Walking down the side it is not noticeable.
Your talking about moving it this much > --- < Pretty sure any decant body shop could loosen the bed bolts and move it 1/4 inch without any problem.
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
That is crazy. Do they weld the bed and the cabs to the frame so there is no adjustment. I would call BS
kpgreenwell
kpgreenwell
Kenny
Kentucky
There are 6 bolts 3 on each side as far as I can tell. I haven't been able to break one loose yet as I need to get an air impact.
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
It is a bit sad and I would be super frustrated that I ordered a $40K item and had to get get the impact wrench out (or go purchase one, or pay a body shop) to make adjustments because the workmanship quality was not up to par. Especially if the dealer said 'looks good to me and it can't be fixed anyway."
vtxrider
Clayton
Utah
2022 Ranger Lariat Scab Hot Pepper Red.
retired software engineer
If you are actually going to buy an air impact I would suggest a battery 1/2 inch impact. My Dewalt has 1200 lbs of torque. I never use my air impact anymore no hose to drag around. My friend bent a 3/4 inch breaker bar using a cheater trying to get off a axle nut. He was going to borrow his brothers IR that had 700 lbs of torque. I told him I could get it off with my battery impact. Like always he called me a liar. I went over to his house and it came off like it was already lose. He was very impressed. Plus you can take it anywhere because you don't need air.
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
Off topic (but at least still FoMoCo) - But I had to remove the rubber drain plug from my Jaguar radiator to change the thermostat housing. This is the preferred and best method from the Jag forum for removal, a nickel in a pair of vise grips. The nickel started off not being bent. When I reinstalled the plug it didn't straighten the nickel back out....
kpgreenwell
kpgreenwell
Kenny
Kentucky
Thanks, I was wondering if a battery operated one would work.
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
2021 no alignment issues.
