- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 169
- Messages
- 7,725
- Reaction score
- 11,034
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
As much as you want to believe yourself and AI, AI likes to contradict itself. Keep in mind that a Strut does not have to have a pivot point up top for the Steering. It simply has to Support and Control the load at the same time. The Ranger and my Frontier along with other vehicles on the market with similar front end designs have what is called SLA Strut suspension. Why is it called SLA Strut? Because you have a Short Arm and Long Arm with a Strut.Coil over is more accurate. Gemini explains it well. A strut is technically a type of coil over.
"The main difference is that a strut is a structural part of the vehicle's suspension frame, while a coilover (typically) refers to an adjustable performance upgrade or a specific configuration where the spring sits over the shock.
It is a confusing topic because technically, almost all struts are "coilovers" (a coil spring over a shock), but in the car world, the terms refer to two different applications.
Here is the breakdown of the differences.
1. The Strut (MacPherson Strut)
A strut is a structural chassis component.1 It doesn't just dampen bumps; it actually holds the wheel in place and keeps the car from flopping onto the ground.
2. The Coilover (Aftermarket/Performance)
- Structural Role: It replaces the upper control arm and upper ball joint.2 If you remove the strut, the wheel hub will flop over and disconnect from the car's geometry.
- Steering: In the front of the car, the strut pivots when you turn the steering wheel.3
- Factory Standard: Most modern economy and passenger cars (like a Toyota Camry or Honda Civic) come with struts because they are cost-effective and save space.4
"Coilover" is short for "Coil Spring Over Shock."5 While technically a strut is also a coil-over-shock, when people say "Coilovers," they are almost always talking about adjustable performance suspension.
- Adjustability: The defining feature of a "coilover" kit is a threaded body that allows you to spin a collar up and down to change the vehicle's ride height (lowering the car).6
- Tuning: Higher-end coilovers often have knobs to adjust "damping" (how stiff or soft the ride is).7
- Non-Structural (Usually): In many performance cars (like a Mazda Miata or older Hondas with double-wishbone suspension), the coilover supports the vehicle's weight but does not replace the control arms. You could technically remove it, and the suspension geometry (arms) would still hold the wheel hub in place (though the car would drop to the ground).
Quick Comparison Table
Feature Strut Coilover (Aftermarket) Primary Job Structural support + Damping Performance + Damping Adjustability Usually Fixed (Non-adjustable) Adjustable (Height, Stiffness, Camber) Cost Lower (standard maintenance part) Higher (performance upgrade) Comfort Tuned for comfort/daily driving Tuned for handling (often stiffer) Installation Replaces structural leg of car Can replace struts OR shocks/springs
The "Car Guy" Terminology Trap
This is where most people get stuck.
- Fact: A MacPherson Strut is a coil-over-shock design.8
- Usage: If you go to a mechanic and ask for "coilovers," they will assume you want to lower your car and make it stiffer for racing/aesthetics. If you ask for "struts," they will assume you just want to repair your stock suspension to how it was when it left the factory."
What differs a Strut from a Shock? A Shock only Controls the load. A Strut also has the ability to Support the load with a Coil Spring. Not all Struts have a Pivot Point on top to turn with the steering.
