Stolen tail light thread
Blue Streak
Larry
I want to know were the market is for all of these stolen lights. Are that many damaged?
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Could be Ford buying them back to keep production running. ?
In reality there may be a tic tock video about making a wall hanger out of them.
One thing that usually happens when you try to stop thefts of things like taillights is there will be much more damage to the vehicle in the end.
Vagabond102
Tracy
Portland, OR
2021 Ford Ranger Lariat (Tremor)
Sorry this happened!
The last person that tried breaking into my rig had his face meet the pavement *ahem* a couple times. Police called it self defense and took the guy away in an ambulance.
Not a violent person, but I value what little I have as I worked hard for it.
SigOris
Greenwood Maine
Retired DoD EE
I was looking in that general direction. I pulled a fastener out yesterday and the OD measures 1/4” approx and is 3/4 long. It’s a sheet metal type screw. Was thinking of a torx with the center pin dome head. Can’t grab it with pliers and unless you’re carrying that torx bit you’ll be out of luck.
My big concern is finding a way to keep the screwdriver punch on the tailgate release handle from happening. That’s collateral damage that would be just as bad as losing the lights!
So further digging it appears they are M6-20mm so that fits your 1/4 by 3/4. I’ve seen the bolt referenced as a a BALLAST bolt. More research needed. The hunt for Jimmy Hoffa continues.
SigOris
Greenwood Maine
Retired DoD EE
Nice fasteners but, I don’t need 500 of them to do 2 tail lights. My guess is the bits are 30 bucks each and if you lose it you’ll be toast too!
A group buy possibly.? 500/4=125 people. Only works being able to get 125 or more bits.
Jason B
2021 XL STX SE 4x2
machinist
OK. After reading this whole thread I took a look at my tail lights and pulled a screw out. The thread almost looks like a license plate screw which is a 1/4” sheet metal screw. I took a 1/4-20 x 1/2” long stainless screw put a little lube on it and put it in by hand so it would not break the plastic. They hold the lights nice and tight and the thief would need a #3 Phillips to get the lights out. One of my saving graces is I have a truck cap that is always locked.
Ah yes, the very elusive hard to find #3 Phillip's.
And before someone goes out and gets off the shelf security screws, just know that Harbor Freight sells a 100pc security bit set for $10.
That's a really good pic of a really bad vulnerability.
Thanks for posting it, I'm sure that will help develop a homemade way to slow someone down.
What a frigging shame. =(
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I was thinking that too. I recall armored plates to cover van door handles, guess some hideous looking solution would be out in the wild.
Jmarler
Jimmy
San Antonio
2021 ranger
Certified Hacker. Retired Veteran
I just installed these and it worked. I recommend using bigger washers. These didn't come with any and I had to use my own.
#14 x 3/4" Button Head Torx Security Sheet Metal Screws Stainless Steel Tamper Resistant, Qty 10 Number 14 Size x 3/4" Length by Fastenere https://a.co/d/6Xw0Nf9
Rick V.
NE Ohio
06 Scab,63 Fairlane, 22 Scab XLT FX4 302a
Fleet bodyman
Jason, The screws are not a fix all just a deterrent. Just like the privacy torx in the other post. Unless they show up like this, then you don’t have a chance.
But if you have two of these from Amazon you would be fine.
DonB
Don
Texan trapped in Communist Delaware
2022 HPR Ranger Super Cab FX4
That's what I have on order
dtech
colorado
I have a security bit set ($8.00 on amazon) - bought so I could take apart a gas valve, now the set is sitting idle, since I have the tools wonder if I should take up thievery as a hobby :frown:.
Seriously those security fasteners shouldn't be much of a detriment to any knowledgeable decently prepared thief.
I remember when thieves were smashing cars windows in NYC to steal car radios which prompted owners to place signs "no radio in car" (remember removable radios ) and a frustrated thief broke into one such car, flipped the sign over and wrote " then you need to get one" .
maybe Ford should design removeable taillights in the interest of staying ahead of the thieves.
