Stinkbug stance on my Tremor
dano42
Dan
California Central Coast
2021Ranger Lariat Tremor, 2024 BMW X5
Retired!
So, I can't put drop shackles on my '21 Tremor to level the stance, and I know this has been covered before, but what can I do to the front end without compromising the suspension or ride quality?
Bravohook
Addame
Victor
2021 Ranger XLT FX4
Sheepdog
Ford ranger lifts .com makes a 1" lift for the tremor which looks good. And will keep factory ride quality. Supreme suspension makes a 2" you can add to it as well. Which is the same as the readylift 2" kit but cheaper. Me personally I think the tremor is at a perfect stance. Its .8" higher than a FX4 and has FOX shocks.
last time i saw a trimmer up close i remember thinking it looked pretty much level from the factory. i guess you could toss a set of adjustable coil overs on it. the ride change would be minimal if even noticeable if it did not make it better.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Yeah, at least on mine it is 1.5" higher in the rear. A 1" level is my plan personally. Enough people have done them without any noticeable change in ride quality.
Someone in here did a 2" front and 1" rear on their Tremor and they claim it rode the same. That has been my other thought but since I tow a bit I will likely just do the 1" front.
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
Any 19 and up Ranger level or lift will work with the Tremor.
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
I bought a second set of springs and dearched them 1.5", fortunately, I found new cheap set of multi leaf global springs to do it to, that way I could keep the Tremor springs stock, I could not stand the stinkbug look and I didn't want to raise the front.
SEkevin
Kevin
Minnesota
Ford Explorer, 2021 Ranger Tremor Lariat
Healthcare
Just put a 1' lift on the front and to me it really looks better. I stayed with the 1" in case I end up towing with it. I cannot detect any difference in ride quality.
Gsd1976
Las vegas
Ranger
Construction
I put a 2" ranger lifts level on mine. I am running 200lbs of winch and front bumper though. Sits perfectly level at all 4 corners. Noticed no change in handling on or off-road.
awd.nv
Anthony
Las Vegas, NV
Computers
That is exactly why I will likely stick with the 1" front level. We tow our 19' travel trailer at least once a month. Adding 1" wheel spacers made a noticeable improvement in towing stability though. Not so much for normal driving.
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
I can't believe you have not been asked what a stinkbug stance is. A real 70's thing
Fawnbuster
Indiana
Retired 34 years as LEO
I did a combo, 1 inch readylift, half above spring assembly and half below the front shock. Then we set the Bilstein 5100s at just over 2 inches +or-. That way I didn't compromise ride quality, got a level lift and larger tire clearance. 2 years later and I have no regrets. Truck rides better than the stock fx4 shocks i swapped out.
Fawnbuster
Indiana
I think the Tacoma's stance is closer to a dung beetle ?.
I was looking at one in the parking lot with that big Ole T R D racing decal on the bed. And thought it needed a U between the T & R...
Dgc333
21 Ranger Lariat
I jacked the front of my Tremor up until the rocker was level, it took 1". I got the RangerLifts.com 1" spacer and I think it is perfect. I see a lot of Rangers on this site where the wheel well gaps are the same but the rocker is going up hill toward the front of the truck.
