steering wheel controls not working
LISANDRO
Lisandro
california
2019 ford ranger xlt
Hello guys,
Recently my battery died and jump started it and then went to fully replace the battery with a new one but after doing so the steering wheel control buttons no longer work. I checked the fuse for the sccm and even replaced it and no luck. Any ideas what it can be?
Did you tell the BCM that you replaced the battery?
Not sure why that would effect the buttons but it could.
LISANDRO
LISANDRO
Lisandro
california
I did do that but had no luck on it unfortunately
Brett Fields
Brett
Brooklyn
2021 Lariat FX4, Blackout, Tow
Paramedic
How is that done? I'm not replacing a battery, but It sounds like something I should learn...
Rp930
Denver
This method seems to work. I have also read it will reset if the vehicle is off and locked with no load for 8 hours.
  1. Get in vehicle, close doors
  2. Turn on ignition (but don't start)
  3. Wait for battery light to come up
  4. Flash brights 5 times
  5. Press and release brake 3 times
  6. Battery symbol on dashboard should flash after 5-10 seconds
