caprtaineddie
Yeah, I don't understand that. I would think that you need the display more in Sport Mode.I am really shocked that is Sport mode the gear only display if you are actually paddle shifting.
It will display in drive mode if you hit the + or - button....Yeah, I don't understand that. I would think that you need the display more in Sport Mode.
Sorry, late to the party ?It will display in drive mode if you hit the + or - button....
Understand that that is the front display to gear lockout. Every - push from the full 10 gear display will subsequently lock out each higher gear. Good for towing, or decending long down hills. Pushing + will then unlock each gear up to 10. The transmission will still normaly shift throught the lower gears in D. Read your manuals folks.It will display in drive mode if you hit the + or - button....
Mr. Phil,Understand that that is the front display to gear lockout. Every - push from the full 10 gear display will subsequently lock out each higher gear. Good for towing, or decending long down hills. Pushing + will then unlock each gear up to 10. The transmission will still normaly shift throught the lower gears in D. Read your manuals folks.
