Sharing a few nice modifications
chasvs
Tampa
2019 Ranger Lariat, 2017 MB GLE350, 2006 Porsche Cayman S
1. Autostop Eliminator - allows you to set disable and it remembers the setting until you change it. No more annoying power-off at every stop. Bye the way, I am averaging 23.7mpg
https://www.autostopeliminator.com/products/2019-ford-ranger-autostop-eliminator
2. Tail-gate dampener - pull the handle and go, it drops slowly while you gather your gear to load
Ford VKB3Z-9946A 10-A
Damper now available through DEE ZEE. Same item, cheaper price. DEE ZEE is the OEM Manufacturer of this for Ford! https://www.deezee.com/product/truck-tailgate-assist/
chasvs
Tampa
The venom is coming from the damper lovers who cant handle the truth.
Waaaa f...... waaaaaa he called me a limp wristed wimp. Arent you wanting a tailgate lifter? :crying::crying::crying::crying:
No venom, just wisdom. You knuckle draggers can enjoy you’re trucks as you like them. Same for those who prefer the finer things in life! ?
Retamaman
2019 Ford Ranger XLT Magnetic Sport, 2020 Genesis G80 3.8L
Plug a 110v appliance into your outlet. In my case, a plug in air freshener; though a night light would also work. The system detects that you're using 110v power and disables start/stop.
This site is so cool! My non-mechanical self would never have conceived of such a cheap work around for this PITA switch! Thank you Ranger Wizards!
DarkRelms
Fort Hood Tx
2019 Ford Ranger xl SXT package
allcos
George
2020 Ford Ranger Scab 4X4 XLT
Can you Explain how to hook this up? I have tow package, if that's needed?
I assume you're referring to the damper. YouTube has some install videos. Quite simple to do. I cleaned and sprayed the exposed surfaces of my bracket plates (masked the balls with masking tape) using black Rustoleum. Wanted to match the trucks color. Maybe tilt the bracket on the truck body ever so slightly rearward for the lanyard to tuck better. You'll see it in one of the videos.
Porpoise Hork
Bret
Houston
IT
Damn I want to know the secret to 23 MPG I am lucky to get 17 currently and I drive very reserved.
Looking into the start stop eliminator.
I don't about @EhrMike but for me it was flashing a custom tune. Multiple people are reporting significant mpg increases, myself included after flashing to custom tunes. I'm currently running the 87 Daily/Tow from 5 Star and it's in the same range as this.
Also the Auto start/stop eliminator is definitely a recommended mod. Installs in about 2-3 min and once set you don't have to mess with it again.
GWJ5603
Gary
Sarnia, ON CANADA
Dredgerie
Greg
Nevada
Magnetic Ranger Supercrew
I just press the button to turn off the auto start stop button
I personally don’t see the big deal. Like the tailgate damper. I’d get one but I Feel like they are ripping me off 50 bucks. Just saying
You can buy them direct from DeeZee for about $36.
Raptor-EU
Henri
Madrid
www.puraleña.com
Ford Ranger Raptor
A lot of nothing.
Both aren't necessary for the EU Ranger Raptors.
1) Auto engine off function can be switched off in the cars menu.
2) Tailgate is spring loaded and can be lifted with your little finger. That said if it is still functionel...
chasvs
Tampa
The Damper isn't about lifting. It's about slowly opening. If your spring loading slows it when it opens then you don't need this.
Raptor-EU
Henri
Madrid
www.puraleña.com
Ford Ranger Raptor
A lot of nothing.
Spring tensions more when opening so the drop is also a lot less. It works with a torsion bar.
