Seeking Rack for Roof top tent that keeps tent at roof height
SafetyDan
Dan
Oxnard, CA
I am looking for a rack that will hold a RTT at a height that keeps it a roof height when traveling.
Any body make one yet?
SafetyDan
SafetyDan
Dan
Oxnard, CA
Both RCI and KB Vookoo (Max Modular line) have universal bed racks that would work for you. Assuming you're looking for a bed rack. Expect to lose at least a couple mpg due to drag though.
I should have said keeps the tent below the roof line.
HoosierT
Tyler
Fishers, IN
In that case the max modular would be better as they have a 10” high option vs RCI’s shortest being 12”. Depending on your RTT it may end up an inch or two above the cab but mostly tucked in there.
tivct
Dearborn, MI
Tremor, Focus RS
I'm in the process of installing rack rails down the bed rails, so I can run standard Yakima racks over a tonneau cover. May be a disaster, I'll update when it's together.
HoosierT
Tyler
Fishers, IN
I'm also going to be drilling through my rails. I decided not to curve the brackets for my bed rack (being built this Saturday) and just have the feet/plates rest and bolt right on the top of the rail as not to interfere with my tonneau cover. Gonna be a nerve-racking endeavor!
tivct
Dearborn, MI
Tremor, Focus RS
Excellent. I'll let you go first!
khyros
Would the Yakima BedRock HD not work? I can't find one with a RTT mounted to it, but it's right about bed height, with a 300# capacity.
tivct
Dearborn, MI
Tremor, Focus RS
It works if you don't want a tonneau cover.
khyros
True, but that was not part of the original request. With that stipulation, I would go with a tonneau cover with a t slot, and then the Thule/Yakima T slot towers.
tivct
Dearborn, MI
Tremor, Focus RS
Agreed. I considered that setup, but the sliding canisters take up too much bed space, especially in a supercrew.
HoosierT
Tyler
Fishers, IN
The nice thing about the Truxedo Pro X15 I have is that it literally only extends over top of the bed rails maybe 3/16" leaving nearly the entire rail for mounting IF you're willing to drill through the rails and top mount a rack, bars, channels, etc. Additionally, I will be able to roll it back completely open with the bed rack in place. The bolts will be on the inside of the legs so they'll be fairly concealed. I designed this so that the inside of the feet land right outside the tonneau rails by about 1/16".
Fordguy
Rich
San Clemente, Ca
Fixed operation Director Tuttle Click Automotive
The Yakama HD rack works very well
tivct
Dearborn, MI
Tremor, Focus RS
Awesome. What hardware are you planning on for mounting? I'm worried about pulling through the sheet metal on the bed rails. It didn't seem like there was a whole lot of room underneath for backing plates/washers. I'll have a ~185lb Tepui tent mounted.
