SCT BDX TUNER
Status
Not open for further replies.
HTX1811
HC
Houston, TX
19 Ranger STX 4x4,16 Audi A7
Can't your tuner just edit your custom tune with your tire info then?
Tuner as in the person that wrote your custom tune
I called 5Star. They said I should see it but since I am not, they are going to contact SCT and get it corrected and put out an update.
HoosierT
Tyler
Fishers, IN
ā€˜19 Ranger Lariat FX4, '17 Explorer Sport
Well hold on. I’m running the 93 performance tune from 5star. I’ve had the same tune for months and did not hit them up for a new tune when SCT released this. Something else strange seems to be going on here.
HTX1811
HC
Houston, TX
Sounds like something else is going on. I have been running the 93 performance 5Star tune since July. Maybe now that the canned tune loaded, I will try the custom tune again and see if it is there.
JaysOnTheEDGE
Jay
Office Equipment Technician
screens load with the 93 Performance unleashed tune loaded up after the device FW update
HTX1811
HC
Houston, TX
No such luck when I loaded the 93 tune just now. Only gives me the option with the canned tune.
I updated the tuner yesterday.
HTX1811
HC
Houston, TX
On a positive note, the adjusted tire size is spot on according to GPS. Cruise set at 55mph, GPS says 55 mph for an extended drive.
JaysOnTheEDGE
Jay
Where do you get the new tire size? did you use the mfgs numbers or a generic tire size calculator? i'm upgrading tires soon lol
HTX1811
HC
Houston, TX
I measured the height of the tire but like the Hypertech, the size to use does not match the tire height. My Nitto Ridge Grapplers are just over 33ā€. I used 31.25ā€ with the Hypertech. It was dead on.
With the SCT 32ā€ was the number. 31.25ā€ was too fast. Reading 63mph at 60 speedo. A little trial and error.
Rob R
Phila
2019 ford Ranger XLT
Septa Railroad
Looking for info.. I just recently bought and installed The Bully Dog BDX tuner, my truck runs much better but having a little bit of a trans issue fourth gear holds a little long then shifts into 5th with a noticeable hard hit. But only driving just normal.. not if my foot is in the petal.. So one question is does the trans still need to learn all over again after the install..
Rob R
Phila
Septa Railroad
That would be Pedal with a D
RangerRaptor
Denver
2019 Ford Ranger Lariat (previously 2012 Ford SVT Raptor)
Are you guys updating your firmware?? I see it says for Tech Support Use Only.
Although I did notice it updated the FW after I updated the device and connected it to my truck. But still no option to change tire size. I'm running 5 Star tunes.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
I have the SCT X4 with tunes from a few different companies and the SCT always asks if I changed tire size and what my axel ratio is before I can download the tune.
njrucci
nick
york pa
2019 ford ranger
What tune do I run? I just bought it and don’t no what to pick? Also I don’t know how to pick a different fire size
njrucci
nick
york pa
2019 ford ranger
What tune do I run for towing?
Status
