Rustproofing?
Which would you do Fluid film or rubberized undercoating
  • Total voters
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Wow you would only see rust like that on a vehicle here if it did a lot of beach work and the owner never bothered to wash it. Even then summer thunder storms do a pretty good job of washing underneath.
Hi folks,
I've seen a few threads on initial rust when vehicles were delivered, but nothing long term. Figured this might be helpful for folks wondering about where the typical spots for rust to start might be and where it is a good idea to focus on rust prevention.
My truck was built in March of 19 and I bought it from the dealer in November of 19, so it has been through 3 full Michigan winters here as a daily driver. They do not spare the salt on the roads here and I've not done anything to it in terms of rust prevention, undercoating, or washing regularly in the winter.
Front fender well, we can see rust starting at the welds ahead of the tire. Some fasteners with surface rust as well. A little bit on the frame area behind the tire as well.
Rear fender well, again welds are where we see rust starting to grow.
Frame in middle of truck looking rearward. Same story here, some surface rust at some of the welds, otherwise frame looks good.
Frame just behind front wheels. This is the worst area, seems like it takes the brunt of the salt spray from the front wheels. If you're spraying any type of RP on the underside, get every nook and cranny in this area.
Rear behind the back wheels. This fared better than the front. The spray must miss most of the underside.
In summary, surface rust seems to like to come through wherever there is a weld. The area behind the front wheels is the worst, but there is no corrosion anywhere on the body itself, only frame and hardware. The mechanical bits themselves (diff, driveshaft, ect) also look mostly clean. The exterior paint is also holding up well, with minimal stone chips.
Sometimes I miss MI...thanks for reminding me of the miserable winter slush...
Metal Geezer
Thom
Fredericton NB Canada
2020 Ranger XLT FX4 Off Road
I use air compressor with the attach picture air gun. Other picture is of another manual spray bottle. I honestly could see this working for non commerical applications. This product doesn't rinse off unless you use some kinda of degreeser. Pressure washer it's self, doesn't take it off. That's why I consider this product. The best. Dries like a wax.
What volume of air is required from the compressor?
mtsoxfan
NEK VT
How much Woolwax are you using per truck? I've seen the stuff they spray here, and it looks like crap. Drips off too.
I'm not expecting paint finish, but something that doesn't look like driving through tar pits...
Steven D Tipton
Ohio
2019 Ranger STX Supercew & Ranger XLT SuperCrew
I'm not using nothing but LPS 3 rust inhibitor. Self leveling and dries like a wax. Only use Woolwax as sprayer.
3-4 quarts. Depending on size of car and thickness I want.
mtsoxfan
NEK VT
Thanks for clearing that up. I never saw a product mentioned, only the picture. Is this a one and done, or yearly?
Steven D Tipton
Ohio
I put on heavy, so I usually tell customer they can go 2 years. Let them decide if they want it yearly. This product is not like fluid film, that water washes off. Pressure washer wont take off unless you use a degreaser.
Steven D Tipton
Ohio
I'll add a update pic of rotor. After all the rain in Ohio. Also a couple pics of wife's car that I did really quick before vacation 4 weeks ago. I put hers on pretty heavy. You can see a couple of thick spot. Rust won't be there, that my main concern.
Jason B
2021 XL STX SE 4x2
machinist
How long does that coating last? Is it a yearly maintenance?
XLT and me
michael
NE Ohio
2019 xlt ranger 62 galaxie
Truck driver
My 19 has been holding up well to Ohio salt. I have been getting the Krown treatment every fall before winter. Daily driver, not garaged, but i do try and keep it washed regularly during winter. Just touched up frame from some rock chips on rear wheel area with tips i found on the forum, it looks factory fresh again.I also Fluid filmed the heck out of it for good measure in areas that take the most abuse. Salt sucks!!!
raymonda70
Ray
Roanoke,VA
2019 Ranger XLT 4x4
Sr.Buyer - Toshiba-Mitsubishi Electrical
I'd rather have rust and snow than hurricanes, earthquakes, and tornadoes.
As a former Buffalo resident living in VA, I'd take the tornadoes any day.. you can keep the rust and dirty snow! :)
