- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,684
- Reaction score
- 8,972
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
From what I can tell, everything on the Truck side should be set.
I think it's in the Start-X module or the T-Harness may not be wired (pinned) correctly.
I cannot find a wiring diagram for the Start-X (T-Harness) that they supply with the unit.
It taps in the backside of the DLC.
Now Referencing the Factory DLC (Front Facing Connector)
This is the OBD Port
Note:
Pin #16 is Power (Always Hot)
Pins #4 & #5 are Grounds
Pin #6 = HS Can High
Pin # 14 = HS Can Low
Pin# 3 = HS2 Can High
Pin # 11 = HS2 Can Low
Backside of the DLC - This is what Start-X is tapped into
This is C2431
So, the Start-X (T-Harness) is just jumper harness (pass-through) powering, non-start-x related wiring, and you will see a splice point or 2 wires running into the connector tap points.
So, T-Harness connects to this connector 14 Wires
Runs to the Start-X module connector
Then reconnects those 14 wires with either spliced wire taps or double wire into the connector pin slots.
I am thinking the Strat-X is tapping 4 total wires, I am not positive on this
But should be tapping:
Power & Ground
HS1 Can - High & Low
The reason for the Start-X, Lock -Unlock-Lock or whatever sequence options it has is to trigger a cycle on the HS1-Can bus to internally power the circuit to produce a (Start Signal)
When you use Start-X - do the doors Unlock & Lock (Cycle)?
Both Power Feeds into this connector are always HOT and Start-X I believe kills that power until it internally sees the (Button Press-Sequence) on the HS1-Can bus (with the doors closed)
or it drops the Ground for the Start-X module.
When you open the door, you are triggering the HS1-Can bus to power and Start-X is now powered, by either opening the power feed or applying the ground.
Depends on how it is wired.
It you can, as it is most likely wrapped if spliced - you will not see it
so hopefully they double wired into the connector end that connects to the backside of the Gateway DLC and note all wires they have tapped.
My ROUGH GUESS is they tapped Pins
#13 for Power
#19 HS1 Can Low
#20 HS1 can High
and Pin #1 or Pin#14 for Ground
As for the Truck, it should be set up, for some reason the Start-X module appears to not being able to power itself from the door lock cycles along the HS1-Can bus.
Note:
This is C2431
Power & Ground
#13 for Power
#19 HS1 Can Low
#20 HS1 can High
