Remote start with the FOB is Lariat only, unless the owner added an aftermarket remote start.Were you close enough to use the fob? I seldom use the app to start the truck anymore.
Might depend on the model year, but my 2019 XLT has factory remote start on the fob.Remote start with the FOB is Lariat only, unless the owner added an aftermarket remote start.
Not all of them.XLT 's have fob start...
The trick with the app is that it can take 1-2 minutes for the signal to get through depending on local cell conditions. my local cell reception basically sucks so I use the start on time function of the app.Not all of them.
Mine doesn't have the remote start on the fob, just lock, unlock, panic.
App said mine didn't start this morning either, closed the app and tried it again, said it didn't start, walked by the window and could see it was running because the running lights were on. SMH
I may have to see about getting remote start through the keyfob added to mine and ditch using the app.
Usually when I try to start it through the app, a popup will drop down and say it could take up to 30secs for the vehicle to start and when it starts it tells me it's running but this morning it told me it couldn't start, but it actually did start it... It was weirdThe trick with the app is that it can take 1-2 minutes for the signal to get through depending on local cell conditions. my local cell reception basically sucks so I use the start on time function of the app.
at 6:30 am I turn on the outside lights see snow, fog etc on the vehicles I open the app and set it to remote start at 7:05 am.
at 7:05 am the truck is running.
however if I push the button it isn't instant. it takes a couple of minutes by using the start time, it can have 5-10 minutes or more to get the signal to the truck itself.
i have it from the factory on my 21 XLTRemote start with the FOB is Lariat only, unless the owner added an aftermarket remote start.
Wrong! My XLT has OEM remote start on the fob.Remote start with the FOB is Lariat only, unless the owner added an aftermarket remote start.
