You, of all people, being a fellow Canadian, criticizing my Canadian Newfie engineering skillsthis clearly tells me the level of your engineering capabilities. I know the risks of angular pressure on glass, yet I also see many ways to overcome this without plunking a massive rod in your field of vision. you solved one issue and caused several more.
If I am not mistaken but there are no DIY projects by "wanted33" in this DIY sectionAnd here I thought my "Redneck" engineering would go unchallenged forever. But, I bow to your abilities sir.
After the "Ranger power rear window" do you really think I would try to out do that? I know my limitations my friend, and know when I've been bested. I mainly master in "Duct tape technology", and minor in "WD40 keeps the world moving" techniques.If I am not mistaken but there are no DIY projects by "wanted33" in this DIY section
Thanks for the compliment.
Here are mine ...
1. Winch with custom made table/stand
2. Truck bed crane used with 2" tow receiver
3. Screen mesh window - for optional rear window.
4. Truck bed protector
5. Emergency power inverter (110 VAC 1000 Watt output)
6. LED tailgate bar
7. Back-up alarm
8. DIY Truck bed covers (Tonneau - 3 different types)
9. Door ding protector with payback.
10. Cargo slider(s) for truck bed.
11. Steel rims with reflective wheel covers.
12. Rear window RF Remote Control Automation
You forgot the last item in the hillbilly arsenal -After the "Ranger power rear window" do you really think I would try to out do that? I know my limitations my friend, and know when I've been bested. I mainly master in "Duct tape technology", and minor in "WD40 keeps the world moving" techniques.
No can do - too many flying garbage trucks aka ducks/geese that will destroy the paint job on my new Ford Ranger.???come to the mountains and breathe in the air (less smokey this week) you'll be amazed at what the highly oxygenated mountain air will do to your thinking
I don't know that I agree about centre push being the only viable option. At the end of the day were talking about moving a 1sqft piece of glass (therefore rigid) approx 1ft to the side. Not a ton of travel happening. A driven linear bearing under the slider would be plenty stiff enough to prevent the window from racking in my estimation. I don't have an "impressive" resume of ranger DIY mods to cite as proof(?) of my engineering prowess but I do work in design and manufacturing glass man doors and we've used a linear bearing system to drive and steer open 36"x78" doors.....
This drive mechanism cannot "only" drive the sliding rear window at the top or bottom due to uneven forces that could twist and bind. It should be designed somehow to drive the window from the center or bad things will happen
