- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 164
- Messages
- 7,543
- Reaction score
- 10,752
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
- Thread starter
- #1
So I just wanted to start this particular post since I'm sure there are some that have been considering a Rear Sway Bar for their Ranger and just aren't too sure if it is a good idea or not.
As we all know the Ranger only has the Front Sway Bar. This isn't necessarily a bad thing as many vehicles on the market have been like this. Other vehicles may have a Rear Sway Bar from the Factory as well.
What is the benefit of a Rear Sway Bar? You have added stability in corners. What downside is there? You get less articulation in the rear.
Besides that I don't see any key things to point out.
Now if you are thinking about one you need to ask yourself some questions. First off if your Ranger is a 4WD, how often do you take it OffRoad? And when I say OffRoad I don't mean a basic dirt road. I mean actually getting out and doing some good exploring and stuff. If you do so quite often then you might be best to leave it be. This comes down to the Articulation in the rear. Allowing the rear to articulate simply helps you keep traction and have less chance of needing to use a Locker(assuming you have one on the truck). If you don't have enough Articulation then you have a higher chance of balancing on two wheels. That can be fun without a locker to say the least.
If you don't go OffRoad then it.might be an alright idea. Some have stated that it helps with Towing. I myself can't confirm nor deny this claim. Honestly when it comes to Towing as long as the tow setup is correct you should be fine. That said it probably would not hurt to add the extra stability.
For a vehicle that isn't towing, it clearly depends on how you want to approach it. From my personal experience with my 2019 Ranger and my 1993 Nissan Pathfinder I can say that even a basic street vehicle will notice some basic stability increases. But if it wasn't included from the factory then it isn't a requirement.
A great example is my 93 Pathfinder. From the factory it has Front and Rear Sway Bars. After i got it I could tell it was a bit worn out on the suspension. After doing a bunch of repairs I did notice it gets better, but it felt like something was missing. Eventually I got back to the Rear Sway Bar. After replacing the bushings and links it felt great. Also thanks to it being designed to go OffRoad from the Factory I feel it still articulates enough. If it didn't have a Factory Rear Sway Bar then I would probably leave it alone for my particular needs and use.
With that all said and don't I would also like some of the other experienced members like @Wes Siler and @Grumpaw to join in and get their input. I would not be surprised if I might be missing something.
