Ranger Suspension, Lift Kits, Leveling Kits
GatorRanger
Thomas
Ford Ranger
Aircraft Interior installer/Finisher
Would anyone be interested in a ready lift 3” leveling kit ? I have one I never got around to installing and just got the loaded strut assembly I’m going to install instead
BigRedDog
Cam
STL
2020 Ford Ranger Lariat FX4
CPA
Does anyone have measurements from either the ground or the center of the hub to the bottom of the front and rear fender for a stock FX4?
Recently purchased a 2020 Lariat FX4 that has some sort of either leveling kit or lift kit. Currently front and rear are measuring around 37.5" from ground to bottom of fender with stock Dynapro tires.
Bob902
St. Louis
RETIRED!!!!
I have the stock wheels and tires. On the rear, I have Fox shocks. I just measured it at 37 3/4. I have Eibach coilovers on the front that are set at one inch. Front now measures 37. Based on your measurements, I would guess the front has been leveled.
GhostStrykre
Bee
Ohio
2019 Ford Ranger XLT FX4
So Eibach's Pro Truck rear suspension for the Ranger comes in two flavors: one with a reservoir and one without.
Is there a particular reason the reservoir would be the better way to go? i've always thought the reservoir systems were a bit extra for anyone who isn't jumping a vehicle. Curious if that thought holds true in this case as well.
Whiplash
Kern
The southwest Missouri Ozarks
2021 Ranger XLT FX4 / 2004 Mazda RX8
The remote reservoir are for added oil capacity......More capacity and better cooling = Longer life...Heat is what kills
the seals....Don't have to jump , just washboard roads will elevate temp...
GhostStrykre
Bee
Ohio
i'd never considered the reservoir as a longevity thing. good to know. thanks so much, that was a TIL!
TxOTRRanger
Clay
Elwood, Texas
factory worker Tyson Foods
I wished I could afford to be in da “”Big Dog Club””……. Are you racing Baja next week?
You and me both @RK Racing. For those of us on a budget and considering the fact that my truck spends most of its time on the highway. That is overkill. IMHO
