Quick question: sandbags behind cab or over rear wheels?
bweslowski
Brian
Brandywine, MD
2020 Ford Ranger XLT
I'm surprised I haven't seen this yet, but tube sand is made for adding weight in your truck bed. I have 2 - 70 lb bags over each wheel in the back of my 2020 4x2 Ranger. It's fine for getting around in Maryland during the winter. https://www.lowes.com/pd/Sakrete-70-lb-Tube-Sand/3067709
ArchitectThom
Thom
Mesa, AZ
2022 Ranger Lariat FX4
Architect
If you want to really maximize the effectiveness, put them behind the rear wheels near the tailgate. That gets you the best moment (weight*length) effectiveness on the rear axle. #math
Obviously the truly most effective spot would be hanging off the back 10ft or so, that way all the weight is on the rear wheels. ?
Wouldn't hanging the bags 10 ft. off the back of the tailgate make your rear wheels a fulcrum and essentially remove weight from your front wheels? This would reduce their grip on the road and make them less effective in 4WD, yes?
Deleted member 1634
Eventually that would happen, yeah. My 10ft was just a number out of the air, it'd have to be much further, but whatever.
But if you have all 6000+lbs of vehicle and added weight sitting on the rear wheels, you probably won't need 4WD. haha So yeah, if you're only objective is to put more weight on the rear wheels for added traction to them, then that would be the way to do it. It's obviously not practical or safe or a good idea or anything like that. But it would put all the weight on the rear wheels. haha
pbethel
Patrick
kingman az
Not an engineer but weight not between the axles will not improve handling. Unless you like hanging the rear end out.
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
For those of us that have the 5 foot bed, putting sand bags directly over the rear axle isn't much different that up against the front of the bed. Either way will work.
Fifth wheels are mounted directly over the rear axle for a reason. Best traction and weight distribution.
