Project Msfitoy V3.0
OFC Ranger
Jack
ZR2
Partsam:
https://www.amazon.com/Partsam-Moto...0NBO/ref=dp_prsubs_2?pd_rd_i=B015H90NBO&psc=1
Probably the same manufacturer, different label on the box.
I bought something recently that was half the price of another seller, different name in the advertisement. However once the item arrived, it was in fact the same name as the original more expensive seller.
I can't imagine how much money is made duping people into buying the same thing, but double the price lol
Partsam:
Amazon is a scam machine...I've found ridiculous prices for obviously cheap items...then on the other hand you can find awesome deals...don't buy the first thing you see lol...
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
bgtruck
Ben
Alexandria
2021 Ranger Tremor, 2015 Cadillac cts vsport
Yes
This is the upper half of the base attachment, Ram Diamond ball:
From passenger side...left side of mount is Ram diamond ball base adhesive 3M to console and small caps to fill the hole...medium clamp to reach the vertical bar for extra support...Ram bike bar ball attached to 9" vertical shaft with NTP ball mount on each end...the lower half is mounted to Ram round plate adhesive to side of trim on drive tunnel:
Picture of the 9" riser upper end with twin ball NTP...short clamp attached to Ram tablet holder:
Another view from passenger side of the bike U-clamp attached to riser shaft...at the bottom is attached to universal round base with ball that's attached with 3M tape:
Overall view from the back side:
Command central:
The left side of steering is mounted with Ram diamond base ball, short clamp and cell phone mount...this one couldn't hold on with just 3M tape so had to be drilled and screwed:
This is coming next...no need for explanation:like:
Regarding command central, what are you reading to get boost pressure readings? I have the Ford Performance Tune module and can't find boost pressure to display out of the choices in the module.
Edward
Edward
Santa Rosa CA
2019 Ford Ranger FX4
Did you have to attach a mast switch panel to Acc fuse? If so what fuse did you use?
Extreme01
Glen
Maryland
2020 Ford Ranger XLT FX4, 2008 Shelby GT500
You are the lightman. I bet onward traffic loves you!!???
If I remember correctly, I think there's a 200 amp fuse on the hot lead to battery...
The traffic doesn't get the pleasure of my artificial Sun...only Big Foot does...otherwise, I wouldn't be homeless...I'd be in jail... ?
The radio puzzle is as complete as I need for coms on the road/trails...I went with a standard dual band which has 25 watts instead of 20 and used Chirp to program it for all 22 GMRS channels + repeaters and NOAA with a permanent inline power/SWR meter....organized chaos... ?
A traditional CB unit still lives on-board but the mic is tucked away in the cubby...just in case someone without a TGD wants to talk, I'll have this old tech to converse with the damper-less cowd... ?
Here I thought I made a big accomplishment Friday wiring up my dual pod lights on my Jeep. :LOL:?
Good thing these aren't standards. You'd never be able to shift with all that stuff there. :shock:
LOL...you'd be wrong my friend...there's plenty of space for a manual pattern under there...somewhere... ?
Sure if you have tiny hands. ??
