Power inverter
Bluebeetle
Colwich ks
2021 ford ranger xlt
freight relocation
anyone know what size power inverter ford installs in a 2021 ranger?
Marmite
Allan
Hickory, NC
2021 Ranger SuperCab FX4
Does anyone know where the 150w inverter is located?
Marmite
Allan
Hickory, NC
Thanks! I’d like to upgrade to a 400-600W range inverter, have to see if there is enough room there or maybe under the seat.
CJBax
Cruiser
Tacoma, Wa
2021 Ranger XLT FX4
Software Development
Following.
Please let me know how this goes for you because I would like to upgrade the inverter as well. 150W at 110V is almost useless. That's far to little current for any of my laptops or almost anything else I'd plug into it. Maybe useful for ac phone charger but then I'd much more likely just plug the phone into one of the USB ports. Something around 400W would be immensely more useful overall, for me. My biggest concern with upgrading the inverter is having access to the necessary gauge wire for the amount of current the inverter will draw at peak usage.
Tom_C
Virginia, USA
System Admin, Retired
Following.
Yeah, that's a lot of juice at 12v. Definitely need to run a new feed with a 40amp fuse.
Just as important as the wire gauge size is the inverter itself. You want one with nice square sine waves. Anything else fry’s sensitive electronics. Yes the cost considerably more but in this case they will last a long time, be dependable and not overheat.
JesseS
Jesse
NorCal (Roseville)
Sorry but you have named both wave forms as one. A inverter is either a Modified Square wave, or a pure sine wave. Only difference is the top of the wave form is squared off on the modified, affecting clocks, motors to a lesser extent, or any electronics that require a full wave form for timing. Very few electronics will be 'Fried' by a square wave, they just won't work, or work poorly, such as a microwave. Most TV's will work fine on a square wave as they have a full wave bridge rectifier on the power supply. Sorry for the long post.
Thanks for the correction. This is more what I was thinking. https://www.amazon.com/dp/B001539BCE?tag=yeb-puresine-20&linkCode=ogi&th=1&psc=1
Marmite
Allan
Hickory, NC
As Jesse mentioned, I will be using a pure sine wave inverter for maximum compatibility. I have a few in mind but will need to think about mounting position. I may end up putting the 120v receptacle next to the usb ports up front and will also need to mount an on/off switch as the inverters are power hogs.
Glocker
Boca Raton
Following.
I'm not all that knowledgeable about electricity, but this surprises me! I ran a portable refrigerator in my Ranger for a round trip from Georgia to New Jersey and back, and it worked perfect for me! I guess I need to check out how much power that fridge is drawing?
Here is my Dometic:
And my Aplicool:
Product Details
Exterior Dimensions:27.2 x 13.6 x18.2 inches
Capacity:48 Quart(45 Liter)
Voltage: 12V/24V(DC)
Rated power: 45W
Temperature Control Range:-4℉~68℉(-20℃~+20℃)
Noise:≤45dB
Weight:30Lbs
Package
1 X Alpicool CF45-LG fridge freezer
1 X DC power cord(12/24V)
1 X AC adapter
1 X Instruction book
