Pedders Big Brake Kit Installed
clizgo
Liz
Spring TX
2020 Ranger Lariat
Self-employed
Do you find these to be comparable to Brembos? I had those on my Mustang and loved them. Am still driving the Lariat like a Mustang and would really like that quick stop back that I had.
dannewps
Dan
Orange County, CA
Ranger
I cannot attest to brembos, as I have never had them on any of my vehicles, BUT these do stop on a dime, considering my steel bumpers that weigh a ton.
Steve23
Stephen
Maryland
2020 Ford Ranger Lariat
Software Engineer
Hey Dan, kind of a random question but what did you use to fill your wheel well? I have gaps in the liner where it looks like you don't. For example, top left of the rear the crash bar I have a gap and it doesn't look like you do
dannewps
Dan
Orange County, CA
Ranger
Honestly, I do not know. I did not do anything special to my wheel wells. I am sorry!
Steve23
Stephen
Maryland
Software Engineer
Dang maybe I just got screwed lol. By the way, growing up in SoCal I wish I was still there so I could pick up all the big parts I plan on ordering... including some some fenders and bed sides. Would be so much easier
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Just a FYI regarding the Pedders Ranger BBK installation.
A. 18" wheels are required... the factory spare (16" I think) and factory 17" will not work.
B. The SS brake lines provided is OK, but have issues.
They attach facing straight up...
Which, with OEM 18" wheels (with 55mm offset) has the line pointing almost directly at the rim. And in my case, actually was rubbing on the rim. With my summer tire/wheel setup with 20mm offset, there was no issue. The line at the caliper end needs a 25° bend in it.
Next, the bracket is not positioned well to NOT bind the line with near 90° bends, and the line can't slip through the guide. Had to bend the bracket to prevent this.
(as adjusted)
Finally, because of the bad angle on the bracket (point more outward toward the tire) the line can, and did in my case, form a "loop" out over the tire and rubbing on the tread. This really showed up after the winter tires were mounted and the line made a heck of a noise as it got caught in the big gaps in the lug pattern. Serious off-road tire would be a disaster.
Now no rubbing, all's good. Other than this brake line issue, VERY happy with the setup.
lariat
Western US
Ranger Lariat
student
(as adjusted)
Finally, because of the bad angle on the bracket (point more outward toward the tire) the line can, and did in my case, form a "loop" out over the tire and rubbing on the tread. This really showed up after the winter tires were mounted and the line made a heck of a noise as it got caught in the big gaps in the lug pattern. Serious o9ff-road tire would be a disaster.
Wanted to get more insights on these installation hiccups. I run 18" wheels with either a 20 or 25mm offset (I forget). But I definitely want what you are describing in terms of performance, whether Pedder's or another brand.
PltFX4
Richard
Minneapolis, MN
Install was quite straight forward. Funny, the only fiddley bit was getting the new SS brake lines threads to start on the hard line... have to be VERY lined up and then all is good. Key item (which I did not have) is to put a slight vacuum on the master cylinder so when you disconnect the brake line (one side at a time) your not fighting the slippery brake fluid constantly drip on you hands and all over the driveway.
The calipers and rotor bolt right up; pads drop right in. Bleed and go.
lariat
Western US
Ranger Lariat
student
So the steel lines did fit? I thought you mentioned they didn't. Thx
PltFX4
Richard
Minneapolis, MN
LOL... kinda forgot some of the issues... had to read what I wrote above to remind myself...
Yes, they did fit but had to bend the bracket to hold them away from the winter wheel/tire setup (18"). Ideally, a 30 to 45 deg angel on the caliper end of the line would be the optimal solution but not a deal breaker. They have work perfectly both summer and winter.
lariat
Western US
Ranger Lariat
student
(as adjusted)
I must have missed reading this prior, but you state that 18" wheels are necessary?
I went from OEM 18's to aftermarket 17's, but improved the poke, going from OEM (55) to 18mm with my KMC's. If 18" wheels are required, looks like I'm out.
PltFX4
Richard
Minneapolis, MN
Pedders does not specify wheel details other then OEM 18"s will work, but not 17s. They don't say "17s will work IF back space of xx.x". As the disc is quite a bit larger that the OEM, thus pushing the caliper outward toward the rim, I'm guessing it would hit the rim, not the spokes, on 17.
lariat
Western US
Ranger Lariat
student
ok thanks....Sounds like it's an unknown at this time.
