Passenger Compartment Fuses
Dunneldeen
PNW
2021 Ranger FX4
So, I wanted to hook-up a wireless charger and 3D printed bracket I got from @DirkM (look here for details) to one of the passenger compartment fuses via a tap. I was looking to hook it up to an accessory fuse. I was not able to find anything that told me what the power availability was for the fuses in the passenger compartment, so I mapped them out myself. Here are the results of that testing.
This is from a 2021 XLT.
Fuse or Relay Number Fuse Rating Protected Component Power Availability
1-Not used.No Power
27.5ANot used (spare).Always On
320ADriver door lock.Always On
45ANot used (spare).No Power
520ABranded audio amplifier.Always On
610ANot used (spare).No Power
710ANot used (spare).No Power
810AAnti-theft alarm horn.Always On
910ATelematics.Always On
105ANot used (spare).Always On
115ANot used (spare).Always On
127.5AElectronic control panel. Climate control.Always On
137.5AInstrument cluster. Steering column control module. Data link connector.Always On
1410AExtended power module (for restraints module and occupant module).Always On
1510ASYNC Module. Data link connector.Always On
1615ANot used (spare).Always On
175ANot used (spare).Always On
185AIgnition switch. Lock solenoid. Push button start.Always On
197.5AExtended power module (for restraints module and occupant module).Ignition
207.5AAuxiliary switches.Ignition
215AHumidity and in-car temperature sensor.Ignition
225ANot used (spare).Ignition
2310AInverter. Door lock switch.Accessory
2420ACentral locking system.Always On
2530ADriver door power window.Always On
2630ANot used (spare).Always On
2730ANot used (spare).Always On
2820ABranded audio amplifier.Always On
2930ANot used (spare).Always On
3030ANot used (spare).Always On
3115ASYNC.Always On
3210ARadio transceiver module. Door entry remote.Always On
3320AAudio unit.Always On
3430ARun/start relay.Always On
355ANot used (spare).Ignition
3615AAuto-dimming interior mirror. Mirror adjustment control.Ignition
3720ANot used (spare).Ignition
3830APower windows.
Delirious
Nick
2021 Ranger Tremor
Not exactly sure what you're looking for. Using a fuse that allows you to put the original fuse back in there plus a fuse for whatever you're connecting to it. I did that on my left-hand side fuse box for an outlet for my radar detector so it will shut off when I turn off the ignition plus I have another fuse tap in there for my dash cams using a Power Magic Pro that allows the dash cams to stay on in parking mode for as much of a time as I want it or until the voltage drops at a predetermined setting by me which in my case is 12.2 V. (I had dead battery issues at 12.1 V)
Dunneldeen
Dunneldeen
PNW
2021 Ranger FX4
Guess I wasn't too clear on the project that prompted the results of my post.
I added a micro2 tap to fuse position 23, wired to a 12v marine socket and Qualcomm 3.0 quick charge adapter. The wireless charger cable routes along the left side of the center console in the crack (based on input from someone else in that other thread) and plugs into the charge adapter. Loose wires and the marine plug are zip tied in the space under the steering wheel, behind the fuse panel fascia. I did this so that the wireless charger could be left plugged in without taking up either of the 12v adapters in the center console.
BCRanger
Miles
Nelson, BC
Ford Ranger Lariat FX4 2020
Software
I think this might be what I'm looking for, I've been trying to find a positive lead to detect ignition. But when it says ignition does that literally mean the engine / alternator is running? Or just that the power button (i.e. w/ or w/o foot on brake) has been pushed? e.g. are the Aux buttons really not active unless the engine is running? (Excluding stop/start..)
Jedadiah
Jed
Central Kentucky
Former '21 SuperCab Owner
I used 35 today to wire up my Homelink garage door opener, and it's only hot with ignition on. I went and double checked after seeing this and the opener only works with the key on. I was going to use 37, which I tested as ignition as well, but the add a circuit hits the edge of the box there and wouldn't seat.
Jedadiah
Jed
Central Kentucky
Ignition on should be with the key in the on position on trucks with keys, and on the keyless models, it should be with one push of the button but not holding to start. Just like you would have it if you wanted to roll your windows down without starting the truck.
BCRanger
Miles
Nelson, BC
Software
Got it. I'm racking my brain trying to think of a circuit that would be on only when the engine is actually running. (Attaching a DC-DC system and smart alternator makes that tricky. While I could live with draw on accessory power only it would really be less worry of main battery drain to just have it drawing when engine is actually running.)
Dunneldeen
Dunneldeen
PNW
2021 Ranger FX4
I didn't actually start the car for any of the testing. It was all with my key out of the ignition, with it at one click (accessory) or with it in the second (ignition) position but not started.
JRRangerAZ
JR
Arizona
2020 Ranger Lariat FX4
1-Not used.No Power
3115ASYNC.Always On
355ANot used (spare).Always On
3830APower windows.
Thank you for posting this. I just went through the same exercise for a dashcam install. Should'a looked here first!
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Very helpful
Thanks for sharing!
Should get stickied
Need to do this for the engine compartment
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
Very nice Very nice, thank you for the hard work!
taildraggerpilot
Carl
Kennesaw, GA
2020 Ranger Lariat FX4, 2022 MINI JCW Hardtop, 1967 Mooney M20E
Boeing Guppy Driver
#35 is a good choice for an ignition switched tap-a-fuse.
taildraggerpilot
Carl
Kennesaw, GA
Boeing Guppy Driver
There are ODB2 splitters available for dashcams. These would allow for most active monitoring modes that pretty much all modern dashcams have.
