Parking Lights
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
It's that "Guessing" and "Should" part :shock: ? I'm an ER nurse we never like those words...are at least our patients don't. "I'm just 'guessing' this injection is the correct dose but it 'should' work" :like:
Just make sure that you give me propofol and not ketamine.
"It's in the BCM module" Did I mention that I'm 76 yrs old...if you get my drift
You must be the first generation of TV remotes...for Dad... ?
Frank
Playing tricks with old people eh? I thought my reading glasses were upside down...
You fixed the video and didn't say anything? Now I'm thinking my mind's going south...
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
The only thing I've noticed is that the lighting stays on for a few minutes, but always go off immediately when I lock the truck.
OFC Ranger
Jack
ZR2
The lighting system will shut off even quicker if you have your high beams on, but the truck is not running.
I found this out by accident. I had the ignition keyed for power, but engine not running while I was testing some aux lights trigger tapped to my high beams. After a few minutes everything would shut off.
I generally try to be a good neighbor so when I am tooting around in garage in middle of night I won't run the truck. Cold start is pretty loud for a bit till it warms up.
M SPEC
M SPEC
South Carolina
2021 Ranger Tremor, 05 &10 Subaru STI, 911, LC +2
ER Nurse/Nursing Instructor Retired
Frank
Hey Frank, So OK, I tried what you showed me in the video...unfortunately that doesn't solve my wishes. I would like to leave my parking lights on 24/7 and have them go off with ignition or shortly thereafter. This settings method only works with auto-on not parking on. If that makes any sense. You also sent me a graph from "Information Displays", sorry to be an absolute dummy but I don't know where that is located and how to get there. Apparently I'm both "old and dumb". Can you believe that as a Nurse Practitioner I can write scripts for drugs :clap: :rockon::like:
Highlander
Frank
Nova Scotia, Canada
Private
The graphic is page 103 of the 2021 manual. Can't help with the rest of your request.
Frank
txquailguy
Biologist
You can control how long they stay on inside the settings menu.....somewhere.
It's kinda weird too.....you can set it for like 20 seconds or 2 minutes....nothing in between.
M SPEC
M SPEC
South Carolina
Frank
Yup as above "old and dumb" Who would have ever thought of looking in the manual !!!!!!! :blush: Once again Thanks.
