P139C 2021 Ford ranger 4x4 Help!!
Anthonypb
Anthony
port mcneill
2021 Ford Ranger 4x4 XLT
Hello
I just had my engine light go on and truck is driving totally fine no issues, no hesitation. Nothing. The code it is giving is P139C DTC. It is a 2021 Ford Ranger 4x4 XLT with 63,000 miles. I’ve read all the forums and everyone is saying a different sensor and part number so I am a bit confused what is causing it and what I should be changing to get rid of the code? Should I be changing part # LB5Z-9J433-B? Any help would be great?
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
DTC p0139 is for the upstream 02 sensor issue, I do not show a p0139c code
Anthonypb
Anthony
port mcneill
It doesn’t have a 0 in the code P139c is the code
Anthonypb
Anthony
port mcneill
Thank you, hope this gets rid of my code, do you know if i need to reset anything or is there away to clear the permanent code after I replace it?
It will reset on its own after replacement, after a few drive cycles., or you can clear it with Forscan
