Overlanding setup for the uncivilized/stealth camper
Espo78
Gainesville FL
2020 Ranger STX FX4
Actually one of the planned mods was/is the Topper EZ lift system. I really wanted a GFC type setup but living in Florida makes the cost/benefit ratio way out of range. Now I'm worried about sealing up the topper but you're right some garage door bulb seals could do the trick nicely, maybe doubled up at the front bulkhead.
https://topperezlift.com/
charwest
charwest
char & tony
On the road
2019 Ranger XL FX4 Supercab
Healthcare
thats a really interesting product. adds a lot of moving parts, but would certainly expand headroom and flexibility. if you were regularly putting the topper on and off, or raising it up and down, i think the bedrail seal will be an important sticking point. perhaps they have a specific system which works well.
it would be tempting in an effort to level the bedrail to just bolt a piece of sealed wood onto the forward bulkhead to level the bedrail all the way around, then it would suddenly be super easy to seal the topper and you could have a long bulky compressible unbroken seal. a ranger topper woudlnt work anymore, but i know there are plenty of trucks which have that setup and i bet there is another model that would work. The other advantage of using a f150 or whatever fits topper is there may be some better mature designs that seal around the liftgate better. let us know how it goes if you go with the EZ lift topper, thats an interesting project for sure.
we originally wanted the GFC (i assume this is the go fast camper) and after some fretting and worry decided to shell out the big bucks for it. then we found out how long the waitlist was and that went up in smoke.
however we have been so satisfied with our system as-is that i dont think we would go back to a GFC. our slim profile, being able to drive into low clearance city parking lots, better MPG etc all seem like fair tradeoffs for us at this point.
Espo78
Gainesville FL
2020 Ranger STX FX4
The EZlift guys claim it seals up just fine. They sell a heavy duty bulb seal as well as the regular topper tape type seal. I keep trying to find videos from people other than the guy selling the lift but theres not much out there. He's been selling the thing for like 8 years though.
charwest
charwest
char & tony
On the road
Healthcare
This is how Retrax filled the bulkhead gap.
The latest RetraxPRO XR tonneau cover design includes a bulkhead foam seal attached with 3M tape which stuck very well to my spray-in bedliner.Earlier Retrax kits used a metal filler channel that bolted down onto the bulkhead using two existing holes.
You may be able to source these parts from Retrax. If not, this may give you ideas.
If I remember correctly, the OEM tonneau that came with our truck also had a metal leveler piece that bolted on to the front bulkhead wall. Might be an easier source if it’s a ford part. But then again I suspect it would be pretty easy to make one with a piece of painted wood, a couple machine screws, and some silicone to seal the edges.
charwest
charwest
char & tony
On the road
Healthcare
Bed Storage II:
Our ranger, as set-up, has more than ample room for stuff, if you're a weekend warrior or going on overlanding rides. But if you are packing a lot of gear for other various adventures because you are living out of the truck, not just using it for trips, or if you are carrying work stuff as well as normal clothes as well as outdoor gear its tight.
To maximize storage space, I made some tubular mesh storage sacks to recapture the last segment of unusable space in our 'build'.
As you can see, in its base state, there is an approximately 4x5" space that is not really usable along the entire edge of the bed, where the lip of the bedrail and topper rail overhang. It is too small for an arm or a leg to overlap tuck in there, and just shoving clothes or gear in there was annoying because they tend to spill out into the bed while driving or tossing around at night.
So i made these:
there are 5 custom sized tubular storage sacks, each with a full length YKK coil zipper and heavy duty cargo netting that is soft enough that it isn't scratchy if touching it at sleep, but open weave enough that you can tell what is in the sack and vents well to avoid mustiness. The total cost of materials was under 20 dollars, plus an hour of sewing time.
It works well, may increase the R value of the walls a fraction when its super cold, and adds a chunk of usable storage if you're really trying to maximize your options.
these are a little overstuffed, they tuck in deeper with less junk in the tubes.
Admittedly, these are especially convenient because they are the right lengths and diameters to fit our slot, but there are various similar options available online for folks looking for an out of the box solution. google keywords for these kinds of products are "mesh, storage, drawstring, organization, bag, etc" ie: https://www.amazon.com/s?k=mesh+storage+sack&ref=nb_sb_noss
Joeiconic
I used to camp in the back of my 1986 Ranger. I didnt like it and eventually just started pitching a tent. Kudos on your creativity, but that setup looks entirety uncomfortable to ME. I guess that’s why there are so many camping solutions on the market, we all have different likes and tolerances.
charwest
charwest
char & tony
On the road
Healthcare
cozy? uncomfortable?
we're flexible and we get in easy enough, and enjoy the simplicity and maintaining the full performance of the truck without changing the profile.
sure ain't for everyone though!
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
7' bed would be super cush. I'd have to get a couple dogs to take up the extra room;)
There is a guy in South America who has a sweet overlanding Ranger build but there they can get a regular cab and 7' bed. A lot of his stuff is adaptable though. Search for the Sin Rumbo channel on YouTube. I'm tall and would be a tight fit in a 6' bed and I had a Sport Trac before where I definitely wasn't going to fit so I have a nice tent and a bunch of related stuff.
Juniper
Andy
On the road
2021 Ranger Lariat SuperCrew
I'm joining this thread late, as I just bought my Ranger. While I'm not planning to camp in the truck, I've learned a lot from the clever tips here posted by charwest and others--thanks! I have one small tip to contribute.
Charwest mentioned in post #4 the difficulty of cutting foam for bedding using a razor knife. My advice: get a cheap electric carving knife (twenty bucks or so at Walmart or similar stores). It cuts through foam like a knife through butter, without compressing or distorting it. I've done this job a number of times, and the carving knife makes it easy.
Gerder
Gerd
In the middle of the EU
but much of that is Ford's fault. there just isnt a good reason why they had to make a dip in the forward bedwall/bulkhead, …
late in here but my 2cents:
the edge (dip?) makes the ladder bracket of the world ranger from mk 2012 till 2022 compatible…
charwest
charwest
char & tony
On the road
Healthcare
interesting. i guess that makes sense, though i cant say i agree with the decision making if that is the reason.
charwest
charwest
char & tony
On the road
Healthcare
Minor update in case anyone is interested in our version of solar. After 5 years of an 80w flexible solar panel duct taped to the roof, mostly living in coastal (salty) areas and lots of rain the panel was finally worn out and cloudy and wasn't charging the power bank anymore.
when I peeled it off this is what I found. The paint is completely gone and the steel is rusty although not perforated.
was easy enough to have sanded primed and repainted before we put the new 100w flexible ecoflow panel on but as a data point:
Not ok to just assume everything is ok under there:)
pickettf3nce
Troy
Arizona
IS Manager
I wonder how much better/worse that would hold-up with some clear vinyl applied between the paint and panel.
