Opinion on Weize Battery
dtech
colorado
Funny....I have that one in the wish list for our rv as a future replacement Regular wet cell's only last around 2 years or so and ours are due for a replacement soon. Always take it off the rv during winter and store it in garage on a trickle charger, but still, 2 years is about the limit.
Well I just went cheap and ordered a Humsienk LiFePO4 100ah from Temu, $113 . They advertise these batteries for 15k and as high as 20k cycles - I'll likely never go past 500
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
but are you as CHEAP as @AzScorpion aka another fellow POLE
How dare you compare my cheapness to another pole. My cheapness has no equal. How many sheet of toilet paper are you using in there? Wipe more efficiently!!
Toilet Paper !!!!! I use leaves that fall in Oct/Nov.....bag em up and store in the garage till needed !!!:blush:
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Well damn I have been beaten. Just go outside and rub in the grass thats super long because I dont mow either. Saves on buying bags!
daniel3507
Oklahoma
2019 Ranger XLT Sport 4x4
What do you guys do if you do have issues with it? Does Amazon handle the warranty? I was on the fence between Odyssey and diehard batteries recently and ended up with EverStart Platinum. The main reason being if there was a problem, you can always find a Walmart anywhere in the country. Also had the same specs as the other batteries while being about $100 cheaper.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Be sure to buy the right charger and switch your solar charge controller settings to the right battery type and voltage values provided with the battery when you swap. Do a complete charge and discharge cycle then recharge and run the ballance to get the full capacity. Reset your inverter cutoff voltage to match the battery BMS cutoff or a little higher. Usually the number of charges is determined by how deep the battery is discharged and the cycle numbers given are usually at 50% SOC. If the battery doesn't have Bluetooth it pays to add a shunt for monitoring. They are dumping these batteries before tarrifs start so many good deals around now.
Fordup
Ed
NY
youtube.com
dtech
colorado
Yeah I've noticed some major price decreases on numerous items made in China , searching shows a wide variance in pricing from companies operating more closely to source compared with US based companies that are buying from China and then taking larger markups.
