One Piece Driveshaft
TJC
Well it's steel vs aluminum. The woods ds is a nice piece but won't work for me. My ranger is a pavement pounder and I'm on the hwy majority of the time. According to his calculator I would be coming close to the max critical speed.
Before you buy any driveshaft for vibrations one should make sure it's the driveshaft causing the vibrations.
The same calculation used on your 2 piece drive shaft is about ~30% worse (I'm being generous here) than his (max speed). Don't take my word for it. Go to the Dana/Spicer web page and enter the two driveshafts specs. The Ford OEM 2 piece is dramatically inferior.
If you are so inclined you can search this forum to find my entry where I specify the Dana / Spicer components used to build both parts. I actually erred intentionally in Ford's favor on a couple of them.
The Tom Wood's driveshaft exceeds the Ford part in every way. Again, don't take my word for it. Do the calculations yourself. Tom Woods has the details on the parts he uses and will share them with you. And he also knows the parts used in the Ford's two piece drive shaft.
I didn't take his word for it, I researched it myself.
He's honest to a fault about his product, and about Ford's. He knows exactly the facts that I am stating, but he is a small business and can't afford to be wrong. He is VERY conservative well below the Dana / Spicer limits. He never bad mouths the competition or OEMs. That is simply who he is.
My truck has never run smoother, even at 100mph. And I never go that fast, but I did to test it. It was smooth as silk going up and coming down. My Ford driveshaft had the shakes below 25mph, and severe shakes above 70-75. Life threatening, lose control scary shakes, until speeds dropped to 60. It only happened once and I refused to let it happen again. I-95 heading north from SC.
I believe it to be a resonate frequency instance, once it started, it progressively reinforced itself.
I did not trust the truck above 60mph after that, and found Tom Woods. All better now.
21rangerCactus
Self employed
I'll look into it more. I just didn't want to pay money for a product that won't suit my driving needs, according to the builder. The aluminum shaft is a good bit more then I'm wanting to pay
At the moment, doing 80/90mph I have no felt vibration.
TJC
Jason B
2021 XL STX SE 4x2
machinist
When I had my 21, vibration always seemed to be between 65-70. Anything above or below was smooth.
TJC
You know how a truck with front end loose from wear (tie rods, etc.) behaves when you accelerate, and the front end begins to shake violently... almost out of control as the wheels start to jump in different directions until you slow down. It is down right scary as the truck jumps out of control.
This is exactly what I felt at 75mph on I-95! The entire truck was violently shaking/bucking! I came off the throttle, too afraid to apply the brakes... it subsided by 60mph, but for 30 seconds I felt like I didn't have control.... and I-95 typically has very heavy fast moving traffic. I didn't drive above 60mph until I replaced the driveshaft.
Smooth as silk since.
Titchadesh
Cody
Utah
2019 Ranger Lariat FX4
Aerospace Master Scheduler
Recently took the truck in for inspection at the dealership and laughed when they attached a ~$1300 estimate to my visit to replace the rear driveshaft because of the grease spray they observed. I told them the Tom Woods was relatively new and asked them if the spray was at the same location as the zerk fitting used to grease it and that was the end of the that.
This is the spray I have after two iterations of topping off the grease after an oil change. Per instructions, I pump until the excess begins to bleed and then wipe it. I must admit this amount on the undercarriage does seem excessive, to any other TW owners—do you experience this much after spray as well?
If this is just a normal side effect of frequently greasing the TW I can live with crawling back under and cleaning again after the excess has a chance to spin off. Just curious what other’s experience has been so far
TJC
I'll check mine tomorrow. I lube it annually. The good news is that area will never rust! :LOL:
COblue
Ross
SLC, Utah
Blue Ranger Lariat, bone stock
Yeah it's like that. I learned my lesson not cleaning enough grease the first time, but it's just rough proof coating now
