TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 47
- Messages
- 4,021
- Reaction score
- 10,159
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
The same calculation used on your 2 piece drive shaft is about ~30% worse (I'm being generous here) than his (max speed). Don't take my word for it. Go to the Dana/Spicer web page and enter the two driveshafts specs. The Ford OEM 2 piece is dramatically inferior.Well it's steel vs aluminum. The woods ds is a nice piece but won't work for me. My ranger is a pavement pounder and I'm on the hwy majority of the time. According to his calculator I would be coming close to the max critical speed.
Before you buy any driveshaft for vibrations one should make sure it's the driveshaft causing the vibrations.
If you are so inclined you can search this forum to find my entry where I specify the Dana / Spicer components used to build both parts. I actually erred intentionally in Ford's favor on a couple of them.
The Tom Wood's driveshaft exceeds the Ford part in every way. Again, don't take my word for it. Do the calculations yourself. Tom Woods has the details on the parts he uses and will share them with you. And he also knows the parts used in the Ford's two piece drive shaft.
I didn't take his word for it, I researched it myself.
He's honest to a fault about his product, and about Ford's. He knows exactly the facts that I am stating, but he is a small business and can't afford to be wrong. He is VERY conservative well below the Dana / Spicer limits. He never bad mouths the competition or OEMs. That is simply who he is.
My truck has never run smoother, even at 100mph. And I never go that fast, but I did to test it. It was smooth as silk going up and coming down. My Ford driveshaft had the shakes below 25mph, and severe shakes above 70-75. Life threatening, lose control scary shakes, until speeds dropped to 60. It only happened once and I refused to let it happen again. I-95 heading north from SC.
I believe it to be a resonate frequency instance, once it started, it progressively reinforced itself.
I did not trust the truck above 60mph after that, and found Tom Woods. All better now.
