SigOris
- First Name
- John
- Joined
- May 18, 2022
- Threads
- 47
- Messages
- 1,242
- Reaction score
- 4,088
- Location
- Greenwood Maine
- Vehicle(s)
- MY23 F150 CC Lariat PB & MY25 Mustang GT Convertible 60th #0807
- Occupation
- Retired DoD EE
- Thread starter
- #1
First, @AzScorpion please delete / close my previous post as I have more info to share
SO, after having received a M-6766-R23, as was I informed of the error in my ways and we'll leave it at that, this kit doesn't fit my MY 22 either.
The lower hose appears to be no issue.
The issue now is the upper hose has a connection port for a Crankcase Pressure Sensor which my vehicle does dot have. OH, the hose would fit like a charm.
So this morning I called FPP and the gentlemen said I quote " that's because you needed to order a M-6766-B23, the one for the Bronco". Can't make this stuff up.
I then tell him that's the first one I RCV'd and the upper hose was fine but the lower hose wouldn't fit.
I did say I was willing to plug the connection port with a screw and fill with JB Weld.
His response, e-mail us at FPP and we'll get you the correct hose.
SO, even if I did order the M-6766-R23 from Levittown Ford, there'd still be an issue.
If you plan to get one of these, I suggest you look at the instructions first, see attached, page 3 of 6, to see if your truck has the Crankcase Pressure Sensor on the currently installed factory hose.
Good Luck.
Good Luck.
