- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 164
- Messages
- 7,540
- Reaction score
- 10,750
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
For me I went with an ARB single compressor that is in the tackle box. Great compressor and actually worth it. I still have a basic gauge that can deflate the tires of course as it works fine. As for traction boards, I feel they are only truly needed in thick mud and Sand of things get to dicyany off-roading I tend to do is pretty mild. I stay in 2wd until I start getting slippage. so on dry dirt roads, I'm still in 2wd, even if they're a bit rough, so long as traction is otherwise good. I'll only use 4hi if those same dirt roads are wet or if there are spots with lots of dry, loose sediment.
one exception is that I might use 4lo so I can coast down really steep (but otherwise mellow) dirt roads and avoid using my brakes.
when I need the traction, I'll use 4hi most of the time, only dipping into 4lo when I need to deal with chunkier stuff. one thing I noticed with the ranger is that in 4hi, there's a pretty sharp throttle response. this can result in some jerkiness as I try to find the exact speed I want to go over a section. using 4 lo here really smooths out the power delivery to the wheels, so small changes in pressure on the go pedal don't automatically mean big changes in power at the wheels. 4lo definitely smooths things out a lot.
where I'm driving, it's twisty enough that even if conditions are good, I'm not speeding along on big straights. I've gotta slow down to deal with turns. on the tighter 4wd stuff, that's even more pronounced.
one thing that's smart to bring in my neck of the woods is an ability to cut out a tree that's down over the trail. whether that's a chainsaw of some kind or a handsaw or whatever, it's a good idea. I already have a chainsaw, so I bring it along when I go out. some of the 4wd roads I've driven, I wouldn't want to be stopped by a tree and then be forced to drive in reverse down the stuff I'd already driven.
I wouldn't mind a nice ARB compressor and quality gear, but I don't go out often enough or deep enough to be able to justify that. I have a basic little electric pump and a basic tire gauge. I can air down and reinflate with those things. even if it might take longer to do so.
no traction boards for me, either. when I learned to drive off-road, I learned to throw stuff like sticks and rocks under my tires when I need it. and I've actually used that technique to get myself unstuck before.
