OEM Style Replacement Shocks
Thanks I have the Eibach Pro's for the rear, was gonna hold off on the fronts.
Just wanted to make sure i could do them myself
LOL! No way was I gonna tackle the fronts in my driveway. I had the dealership do it. Look into it and see if it's in your wheel house. It's a lot more complicated. Plus you need an alignment done after.
Iowa Guy
Cental Iowa
2013 Fusion SE, 2021 XL Ranger Supercab STX 4x4
Automotive Tooling Engineer
Lol, that's what I meant. I have the eibachs to put on the rear (myself) not doing the fronts at all
Then you should be fine. The rears were pretty easy. I found that if you work from the opposite side of axle, meaning if you are working on the drivers side, work from in front of the axle, doing the passenger side, work from the back of the axle, it makes getting leverage to compress the shocks easier. No jack or stand necessary.
Langwilliams
Langley
Lorain, Ohio
The only problem I had was he Eibach's were so stiff I couldn't push them up to slide the bottom bolt in by hand. I was living with a torn rotator at the time but I'm not sure I could have done it by hand if I wasn't. I used a small floor jack to raise the shock up into the lower bracket.
puckdodger
Oshawa
The only problem I had was he Eibach's were so stiff I couldn't push them up to slide the bottom bolt in by hand. I used a small floor jack to raise the shock up into the lower bracket.
Same here, simpler than tie straps or ratchet straps too.
JonB
Elmhurst, IL USA
2019 Ford Ranger XLT
Thanks to all of the insightful information here I just ordered a set of Bilstein 4600s for the rear. I love my truck but the back end is just too busy. Looking forward to these smoothing out the ride.
mustang marty
new england
2019 ranger stx sabertooth , 04 stang ragtop 40th anvrs. , 66 stang fastback 2 plus 2
A happy retired guy
Did the same I love the ride now with the 4600s ; just said the same on another thread . Summit Racing has them .
Iowa Guy
Cental Iowa
Thanks for the insight, i am looking at installing these this weekend, looks like I may need a bottle jack before then then to finish these.
Progeny2021
Charlotte, NC
I ordered Bilstein 4600s front and rear on 11/4 from SD Truck Springs. The rears arrived about a week later and the fronts are still on national backorder apparently. I've been in Florida since early December - going home next week. Image from Hugenot Park, Jacksonville, FL (2019) and local hotel (current).
I found that if you are working from the opposite side of the axle, you can get much more leverage to get the shock compressed and up into place by hand. IE: with the shock that is mounted rear of the axle, attack it from in front. Once up into the bracket, a good size screwdriver or prybar helps line up the bolt hole. I tried a strap, a floor jack and they were just too cumbersome. YMMV.
