OEM Magnetic Takeoffs
danotech
KC
2020 Ranger
Looking for 17” OEM Magnetic takeoffs somewhere around the Kansas City area.
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
Click "FORUM" in the header, and scroll down to "Marketplace",. There is a section that has wheels, and tires for sale. You may be able to find some there. Good luck. It seems everything I might want is on the other side of the country. :)
cb4017
Northern Nevada
2023 F150 Rattler
Retired USN and retired LEO
Thanks! They are on the way!!
Cool, Glad that worked out for you. If you need TPMS sensors the Motorcraft TPMS42 is what you need. Available on Amazon.
danotech
danotech
KC
2020 Ranger
Should be able to reuse the factory ones and transfer to the new wheels??
Washashore
JM
Cape Cod, MA
2019 SCab Lariat 4x4
Yes, you can re-use the TPMS sensors, although a lot of tire shops will want to install with a "TPMS rebuild kit" which replaces the valve, cap, and valve stem. The rebuild kits are inexpensive (less than $5).
The TPMS system will re-calibrate itself after a short drive, so no re-programming involved if you use your original sensors or a new set of TPMS-42 sensors.
