Thanks! They are on the way!!I found one on ebay. I wanted to make my spare a road wheel.
Here is a set of 4 with free shipping.
https://www.ebay.com/itm/2019-2021-...521119&hash=item2af970eaa3:g:K2cAAOSwmRVfiKj2
Cool, Glad that worked out for you. If you need TPMS sensors the Motorcraft TPMS42 is what you need. Available on Amazon.Thanks! They are on the way!!
Yes, you can re-use the TPMS sensors, although a lot of tire shops will want to install with a "TPMS rebuild kit" which replaces the valve, cap, and valve stem. The rebuild kits are inexpensive (less than $5).Should be able to reuse the factory ones and transfer to the new wheels??
