Non starting issue
Conor
Conor
Scotland
2022 wildtrak 2.0
2022 Ecoblue 2.0l Wildtrack in the UK
I changed the leaf springs, towbar and added some semi air suspension units at the weekend. Since then it's not started.
The battery drains quickly, I replaced it but the same happens with the brand new battery. Dash shows engine management light and battery light. Nothing happens at all when I try to start the vehicle.
I connected Forscan and have these faults below. Any suggestions on what I've done to stop it starting? All wiring and connectors look fine. All fuses and relays checked and operating.
Thanks for any suggestions
Code: U029E - Error
Status (-50):
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II (PCM)
Code: U02A3 - Error
Status (-50):
Code: U101A - Error
Status (-50):
Code: U010E - Lost Communication With Reductant Control Module
Status (-27):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Code: U029D - Lost Communication With NOx Sensor 'A'
Status (-27):
Code: U029E - Lost Communication With NOx Sensor 'B'
Status (-27):
Code: U02A3 - Lost Communication With Particulate Matter Sensor 'B'
Status (-27):
Code: U101A - Lost Communication With TCM - Multiple Bus
Status (-27):
Code: B1313 - Interior Lighting Output
Additional Fault Symptom :)15):
- Circuit Short To Battery Or Open
Status (-0A):
Module: Body Control Module
Code: B11DB - Battery Monitoring Module 'A'
Additional Fault Symptom :)08):
- Bus Signal/Message Failures
Status (-0A):
===END BdyCM DTC B11DB:08-0A===
What was disconnected for install? and the air suspension units electric?
RangerBill
PA
Possibly a blown fuse or connector left disconnected.
RangerBill
PA
Did you disconnect the connector to the TCM module? If it was not plugged back in correctly, that might cause a no start issue.
aspenridge31
Chattanooga
2011 Ford Ranger XLT
Those U-codes are modules dropping off the network together, so it reads as one shared wiring fault, not five bad sensors. After leaf springs and towbar work I'd check the rear chassis harness and grounds for anything pinched, and see in FORScan which modules still answer.
Conor
Conor
Scotland
2022 wildtrak 2.0
Thanks for the replies. I've checked every single fuse in the cab and upper and lower engine bay fuse areas, also checked the relays are working fine.
I've double checked all the connectors are put together and secure. -ve wire from the adblue shows as being good.
Not sure what the TCM module is, but as I said, I've double checked all connectors in the area.
All wires appear fine, none pinched or caught out of place.
Air suspension wiring is currently not connected to rule that out.
I'm wondering if there is a way to test the wiring harnesses for any broken wires?
Can I please go back to a 1980s vehicle without any electrical magic to stop it starting!
RangerBill
PA
TCM (transmission control module). In F150's a poor connection to its connector will cause a no start. You have some DTC codes concerning that module. Our Rangers don't have a TCM, it is integrated into the PCM (powertrain control module).
