New Owner Questions - Not in the book
SemperVee
Dar
Olympia WA
1 - I know it's a ten speed tranny. Test driving the F150 you can see what gear you are in- How can I do that in my new Ranger? is is possible while in "D" Drive to see what gear it is currently in?
2 - Voltage meter. Are we able to see the voltage read somewhere in the dash? I like knowing that I am charging when driving and often do battery voltage check when doing maintenace items to see the condition of the battery. I was surprised when I brought Vroomhilda home she was not at a good resting voltage so I slow charged it up and now all is well.
SandBaja
Larry
San Diego
2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
Almost retired
1. On the shifter hit the + or - button while in drive. You will see the gears displayed in the cluster.
2. I am unaware of a volt or amp gauge in the cluster. It wouldn't surprise me to find a battery in a new car not at full charge.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
DHare
Missouri
Amazon has these voltage meters that plug into your 12V port. They work well. I got one after my battery totally died and had to be replaced. https://www.amazon.com/your-orders/...ryId=&returnUnitIndices=&shipmentId=DxpRNMmZ1
Mobius97
Seattle
Ranger Lariat Fx4-Lotus Evora-Lotus Elise-BMW X7 M
I did the same thing with mine. I knew the truck had been sitting for a while on the dealers back lot so decided to throw it on one of my tenders when I got it home. Charged her up to full and let it maintain overnight.
I stumbled across this post as a search because I am wondering if other folks are having parasitic drain. I am used to it on my sports cars and they sit on tenders constantly. I would think the Ranger's battery would be more robust. Granted I don't drive the truck very often maybe once a week but it seems to drop quite a bit. I put one on it today to check because it had been sitting for two weeks w/o a drive and the Schumacher said it was at 55% when it ran it's tests. So curious to what others are seeing after a week or two of sitting. I haven't had any issues and she starts right up every time even when I don't throw it on a tender.
Hi M97,
I had to fly to Michigan for two weeks to tend to our intellectually challenged daughter and her life partner who is equally damaged. The Ranger sat for two weeks in the airport parking. I got a notice on my email that the Ranger had noticed I had not started it in two weeks and went into a power down mode to preserve the battery. Truly amazing that the vehicle recognized a storage condition and dropped parasitic electrical loads, but non of my settings were affected.
best,
Ford Motor Co. Retierd
VAMike
2019 Ranger Lariat SuperCab
The first press of - doesn’t start locking out.
Yes, but sometimes people double click by accident. You can press + until your thumb falls off and the only ill effect will be to your thumb. :-D
Mobius97
Seattle
Hi M97,
best,
Thanks Phil for that tidbit! That is good to know and will give me some peace of mind. Who woulda thunk! I haven't had any alerts yet but good to now know about this feature.
If you're going to be away for any long periods you could always set up a auto start schedule on your Ford Pass App. or just turn it on manually from the app for a few minutes to let it re-charge.
Lunchbox88
Logan
Missouri, USA
2019 Ranger SuperCrew FX4
Hi M97,
best,
Didnt know this was even a thing, learn something new every day. Thanks!
cujoquan
Jarrett
Erin, Ontario, Canada
2019 Ford Ranger Lariat
IIRC you'll need to turn the ignition back off manually via the app in order to be able to remote start again - for a case where you're not getting in the truck and driving off after. If you let the remote start time elapse fully (5/10/15 min depending on how you've configured it) it prevents another remote start until the next key-on event (i.e. you sit in the truck and start it up).
I could be wrong if that behavior has changed, but that's how the feature used to work.
UncleBob
Fullerton, CA
2019 Ford Ranger Lariat SuperCrew 2WD in Magnetic
I recently did a remote start. While I was away at dinner with the bride, I remembered I had not retracted the mirrors (I do it to give more clearance between truck and garage refrigerator). As we drove in the neighborhood tract, I remote started the truck so I could just reach through open window and press the mirror button as soon as we parked next to the truck. Of course I did it this way so I wouldn't have to run into the house to get the fob. (Of course I was showing off to the bride as well. LOL) Anyway, our daughter was in the kitchen and heard the sound of the truck starting and was wondering what the hell was going on until she heard the garage door opening with our approach.
Robert Scott
Redding, CA
2020 Ford, Ranger Supercrew Lariat
Aerospace Engineer, retired
My Lariat, the LEMON that Ford repurchased sat for 6 weeks. I too got a notice that it had not been started in two weeks and went into a power down mode. Six weeks are up----started right up, no problem!
