Metal clunking noise
Mikeymac25
New york
Cheeseburger Walrus
Hi all looking for some help here about a month ago i had mammoth leveling spacer and alignment done no issues no noises at all and about 2 weeks ago i installed new pads and rotors all around (powerstop kit). Now about two days ago after driving to a fishing spot on gravel im noticing a abrupt metal clunking noise while hitting small bumps, potholes etc. I just had the wheels off double checked the torque of everything and couldn’t really find anything loose or broken the only thing i did notice was the outside brake pads on the front have the slightest bit of wiggle and the stabilizer bar bushings look cracked. I am completely unsure of what’s causing the sound any insight or ideas would be great.
side note i do have full warranty if i can’t figure out a quick fix may just take it in for service but worried they may something about the leveling kit as the issue
RangerBill
Were the anti-rattle clips installed on the brake pads?
I am posting the following thread as a ref for the sound.
and noted that the Powerstop Brakes can possibly tie into your complaint (noise) issue.
Does your noise sound the same as the ref video (below)?
If yes and your noted pad wiggle, could possibly be pad placement (I/B-O/B) swapped, IDK if the Power-Stop pads make a difference or exactly how the OE differs except for the NOTE in the manuals for ensure proper placement. I have not had mine apart to physically see why that note is there.
another possible could be that the Power-Stop pads may have a slight MFG difference that allows them to rattle in the anti-rattle clips vs the OE (size difference)
I could be off track here - but just wanted to point out a POSSIBLE source.
Now the Links appear cracked would require a pic for visual look, I am sure there are pics on here for the links or even look on-line for one and compare that to yours, I am sure this sound would be a deep metalic thud going over bumps etc.
Clicking Noise | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Simple things that can be over looked….
  • Loose or popped anti-sway bar link
  • loose lug nuts
  • 1/2” drive rolling around the storage compartment ?‍♂
Mikeymac25
New york
Cheeseburger Walrus
  • loose lug nuts
Yeah going to double back on it tomorrow morning pretty much thinking it’s the brake pad with a little play in it hit the same bump once while breaking and once not braking and the noise is only heard not breaking how I’ll resolve that idk lol
RangerBill
Check this out:
Check this out:
Good reminder Bob. Every time someone posts this bit of info, I always say to myself, “Oh yeah, I’ll have to remember that when I replace my brake pads”. Then, time goes on and I see it posted again and think to myself, “Man, I forgot about that - gotta keep that in mind”.
When the time comes to swap them out, I’m totally going to forget. ?‍♂ ?
shovelhd
Cape Cod, MA
2021 Ford Ranger Lariat
retired electrical engineer
Did you clean and lube the caliper guide pins? If they are frozen or sticky, the pads may not be properly loaded by the caliper, and could make noise.
RangerBill
I was surprised to see that the inner front pads have a left and right side, while the outer pads are interchangeable. I wonder what is different on the inner pads and how are they marked for left and right side installation?
Mikeymac25
New york
Cheeseburger Walrus
Almost positive this is the issue found one of the old oem clips and there is a noticeable difference in size does anyone know where i can buy just the clips?
RangerBill
Mikeymac25
New york
Cheeseburger Walrus
im just realizing my kit didn’t have these clips how detrimental are they for fitment or are they wear indicators
Grandaccess
Binghamton, N.Y
Computer Consultant
I just had my yearly inspection and they found a bad passenger tie rod? I dont feel anything, I dont hear anything and it tracks straight? but it didnt pass
BigETire wants $505 and the dealership wants $600 I am kind of leaning toward the dealership because I know it will be fomoco parts?
RangerBill
