Manual Shift Buttons Stopped Working
RMCB214
Ryan
Washington State
2021 Ranger Tremor, 2020 F150 4WD, 74 Bronco
Marketing
21 Xlt Tremor. Approximately 15k miles. I use the manual shift buttons to lock out higher gears daily. Noticed today that they have lost their function. Anyone else have this happen? A couple on/off cycles didn’t remedy the issue. No codes or errors on the dash.
Dereku
Chicagoland Area
Does it still bring up the 1-10 numbers on the dash when you tap it once? If not I would suspect a bad button.
RMCB214
RMCB214
Ryan
Washington State
Marketing
Nope, nothing changes on the dash.
Neither the up or down button do anything?
To fully T-Shoot this requires a scan tool that will show the following PIDs and wiring checks
SST - U , SST -D and TR Range Corrected
SST = Select Shift Transmission (Up / Down)
So the issue can be in the Shifter - TR Range Sensor and or cable or in the (SST) switch circuit
Just below the shifter boot and (aft) is a small connector for the shifter knob - pull and reseat that connector, this feeds those switches plus below the shifter is the main connector for it, also try pull and reseat.
These are 2 quick possible solutions without digging into full T-Shoot.
You may also try, rocking the shifter back and forth while pushing the buttons to see if you get some kind of operation out of the switches.
And cycle the - Tow/Haul Switch
Another connector in the circuit that contains wiring for the (switches) is C3049 located here so another connector to try - Pull & Reseat if the shift knob and shifter connectors are no help.
RMCB214
RMCB214
Ryan
Washington State
Marketing
Great info. Much appreciated. Tow/Haul functions normally and so does sport mode. I do have a temp version of Forscan so I'll look for those codes and will check the electrical connections. Would the "SST = Select Shift Transmission (Up / Down)" code mean the switch/knob assembly is the culprit?
Quick search online shows the complete shift knob as the only replacement option for $75. Not as bad as I was expecting. JB3Z-7213-AB
The PID is the PCM (signal) of the switch input not a code, basically when you press the (Up or Down) switch - is the PCM seeing the switch inputs. Not sure if Forscan will have those PIDs.
Popped the boot loose and the wire harness was unplugged. Must have been barely secured from the factory. I don't see any other way it could've come loose. All good again.
Wow, glad that was such a simple fix.
TheExtra404
PNW
2022 XLT Tremor || Cactus Grey ||
I throw rocks for a living. ("");,,;("")
wow, super easy fix. Good stuff.
