Major Ford recall announced for trans related issue
Beach
Multiple
2019 Ranger Lariat, 2016 BMW M235, Volcon Grunt
Financial advisor
They just recalled 740,000 vehicles for transmission defect that can ‌'damage the park system, which in turn could result in vehicles rolling away'. Not Ranger trans issues of course :mad: the recall affects 'certain 2018-2021 ⁠Navigator, Expedition, 2020-2021 Explorer, Lincoln Aviator, and 2021 F-150 vehicles, the regulator said.'
Hmmmmmm......
Nothing on the Expedition Forums yet. But even tho mine is a 2019 Expy bought used from a Ford dealer I will still get the recall notices....have received 2 already.....
Rrrr-Anger19
Ryan
Illinois
Unemployed
Previously owned a 2019 Ranger before an elderly lady demolished it, ruining several years of building it up to the way I wanted it... starting all over with a newly acquired 2023 Ranger having salvaged a great deal off the old wreck but not everything sadly...
Anyways I was stunned when I jacked up the rear slightly to level the truck out just enough to do the front diff & transfer case fluid changes, the second the rear tires left the ground the dam-thing started to roll back!!! A bit of context... this 2023 was obviously purchased used and I haven't gone through everything yet like I did my 2019. The brakes being one of them, but this truck only has 42K miles however it does come with the Ford tow package and I suspect it did see some tow usage looking at the pin connector. But my 2019 never rolled back once and that truck had more miles prior to me changing the front brakes.
A brake job is on my radar anyways and after that scare got bumped way up my priority list, but its not like the truck doesn't stop fine even suddenly... however not as good as a truck with fresh pads and rotors.
Anyone out there have a similar experience with their Ranger?
TxOTRRanger
Clay
Elwood, Texas
factory worker Tyson Foods
Wow, that's more than a little bit of a scare when a vehicle rolls back like that. I'm sorry about your 2019 Ranger. Here is to hoping that you can get your 23 repaired.
Mighty Little Blue
Printer/Retired
Am I missing something what would stop if from rolling with rear tires off the ground, maybe if it was in 4WD. That is why the wheels on the ground should always be chocked.
davidtg7123
Pittsburgh, PA
2019 Ford Ranger XLT
Given the RWD, the transmission in “park” is stopping the driveshaft from spinning which is only affecting the rear tires. The parking brake only goes to the rear tires as well, so if the rear tires are off the ground, the front tires can spin freely. Always chock the front tires if you’re jacking the rear (and vice versa just to be safe when jacking the front). Good lesson to learn now without anything breaking or anyone getting hurt. I’ve never owned a RWD vehicle so I almost made the same mistake until my granddad was stopping by to drop something off and saw me out there and called me out on it
OCL
Mission Viejo, California
2021 Ford Ranger Tremor
The PARK feature on the transmission is just a heavy metal rod that goes into another metal Hole or Notch in the transmission, which locks the transmission/driveshaft and REAR axle. Or something to that effect and they call it the "Parking Pawl" in the trans. Does not lock the front tires. Same with Parking brake, which only locks the rear tires. So if you are going to lift the rear, make sure the front tires are chocked or already on lift blocks.
