Locker discussion
brroberts
Randy
Overbrook, KS
audio / semi retired
I don’t want or need a 4x4, but I have the elocker. It’s handy in all kinds of situations in low traction. It’s enough for my needs. I don’t need 4wd, but do need the locker, and in farm country, we all drive off road.
Nomadjohn
Colorado Springs, Co
2021 Ford Ranger Lariat FX4
This! There are lots of cases where being able to lock that second wheel is enough and this saves the weight and complexity of having a full 4wd system. If you don't want or care about 4lo having an elocker will give you just as many locked wheels as 4hi for a lot lower cost.
jleds
Jay
Honolulu
2019 Ford Ranger XLT
This may not be the proper thread for this but does anyone know of Torsen/Limited Slip diffs that are available for the new Ranger yet? Thanks in advance!
None that we are aware of. Also with the way thi vs are going I don't suspect it will happen
Superdannyboy
Anyone know how to keep the rear locker engaged at any speed so that it doesn't shut off past 20? Anyone done it in forscan?
And yes I'm aware of what comes with that, I'm just asking if anyone has done it and how to do it.
Thanks.
Not sure if there is a way to shut that feature off for the E-Locker. That said with the design of the E-Locker vs an Air Locker you dont want to keep it engaged at high speed anyway. An Air Locker will hold up.and keep things truly locked vs an E-Locker will have a little slip in it. If you look at videos on how an Elocker will engage it will explain what i mean a little better. Due to that design it makes them a little weaker(vs the Air Locker) and a high torque load from a wheel coming off the ground and hiting the ground right after would most likely cause it to shatter.
I know its not what you want to hear but it is what it is
Superdannyboy
As long as I land with my foot off the gas I should be fine.
Living The Dream
To the question of why need a locker for 2wd:
When pulling a boat up a slippery ramp, the rear locker is a blessing.
