Lift/Leveling kits
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
I was wondering about a leveling kit too. This video is from 2019 but it has me concerned before I just toss on any 2.5" level kit on a Tremor.
I plan on towing a 19ft travel trailer on weekends so I am waiting till I get some towing miles in. That said, 1.0-2.0" would probably be ideal for my planned use. I think the only level kit under 2.5" I saw was from Traxda. Anyone else see anything?
awd.nv
Anthony
Las Vegas, NV
Computers
Well, I emailed Fox and this is what they said
" The Oem Internal bypass shock is not adjustable and being that it is position sensitive I cannot recommend any alterations to your suspension. "
So that said, I may try a small 1" lift kit but otherwise, I think I may end up just getting the 2.0 later on.
BCRIDGE
Saya
BC Canada
2021 Lariat Tremor
project manager
I am actually considering a different route and replace the front fox 2.0 with the adjustable version (0-3") Fox 985-02-133 versus a spacer . Curious though if I need to replace the UCA with a camburg one or if the stock one will be ok.
Synyster06Gates
Austin
Liberty Hill, TX
Don't get me wrong, I want mine to sit level too - but I don't understand the rationale behind paying extra for an offroad package that's nearly all suspension upgrades, then changing the suspension. I saw the same thing when people bought the TRD Pro when I had my old tacoma.
awd.nv
Anthony
Las Vegas, NV
Computers
Well that's exactly why I do not want to swap anything out and will be trying the Traxda 1" level kit first. The Tremor package offers a lot more than just the fox shocks/coil overs too so just swapping front ones for adjustable ones is not that big of a deal either. I am sure someone will buy the OEM ones used.
halligan1201
Byron, IL
2020 Ranger
Emergency Management
The Tremor already has an outstanding Fox suspension set up. If they’re not adjustable, and your looking for a little more level, I’d go with a quality spacer . I used the Rough Country 2.5” kit, and Im very happy with it.
Agreed. If someone is planning on lifting a Ranger, the Tremor is the wrong truck to buy. You're wasting money buying a package that is purely based on a factory suspension tune and then tearing it out. WAY cheaper to buy a base 4x4 or FX4 if you want the skid plate and lift that.
navyguy7224
Patrick
Denison, TX
2021 Ranger Lariat CC Tremor
Ford Service Tech
I put a 2.5 leveling kit from Rough Country and upgraded my wheels and tires. 18x9's
What spacers/backspacing on your rims are you rocking. That is how I want my Tremor to look eventually.
For those with the 2.5“ spacers, any reason why a 2” spacer isn‘t enough for a level? Measuring from the ground to the fender lip, my fronts are 37” and rears are 39”.
There are few reasons for only going with a 2” spacer - or even smaller.
  • Some folks like the look of a small amount of rake
  • Others want a little rake so when they tow, they’re level
  • Some have concerns about ball joints
  • Others carry a lot of weight in the back (Decked systems, etc.)
  • Some tow a contractor’s trailer daily
  • Some have a heavy fibreglass canopy or bed rack with an RTT
I’m sure there are other reasons too.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
I have noticed a few items like the level kits and the replacement Ford Performance HD Diff cover that say "not compatible with Tremor" but I have No idea why.
The "best" way is a replacement adjustable coil-over from Fox or whoever.
That said I did the Torch off-road 2.5 spacer from Amazon. Quality seems just fine. "If you aint got no Torch bro you aint got s#%t!"
Cpore55
CJ Pore
Kansas
2021 Ranger Tremor
Inventory planner- Meat solutions
just looking for complete clarity, you were able to install the rough county 2.5 leveling kit on it and there was no issue getting it installed?
thanks
Cpore55
CJ Pore
Kansas
2021 Ranger Tremor
Also,
Did you sell your tremor wheels? How much did you get if so?
Hows the ride quality?
FKNRANGER
Matt
Missouri
2021 Ford Ranger Tremor
Network Engineer
Also,
I tried nobody would buy them, so I have them for winter. The new wheels ride great and quite.
BCRIDGE
Saya
BC Canada
2021 Lariat Tremor
project manager
OK as a follow-up went back and forth on this and will be installing a TRAXX 1" lift this Friday. Interesting enough I measured from the top of the wheel well to the ground front on all 4 corners and am showing a conistent 1" inch rake between front and back. Will see what the trax kit does. Really looking to offset any clearance loss with the shrockworks winch/bumper add. Decided to live into the stock suspension/tire package for now...till the trail take its tollon it or something significantly compelling shows up in the future.
