Lane Keep assist
Deleted member 1634
I have it on, but in New England the roads suck and it goes off a lot when it shouldn't. I'm going to check my settings tomorrow to see what I can fiddle with. Lately on short trips I just shut it off.
I get that same sort of thing a lot here too where they tar seal the cracks and the truck thinks those are lines on the road. Another reason why mine is on alert mode only.
MannyS
MannyS
Manny
Winder
2019 Ford Ranger XLT FX4
Thank you!
From what the manual says the steering wheel will only vibrate if aid mode cannot correct the lane departure. Good to know, will test this on my way home.
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
After trial and error, I finally settled on alert mode only, as there are times when I may need to maneuver or change lanes quickly without time to signal, and I don't want to have to wrestle with the steering wheel to do so. Still, it is helpful to have those reminders for the times when I may inadvertently wander too close to the lane divider....
Jon Olivier
Jon
Bishop, CA
2019 XLT 4x4 - Hot Pepper Red, 302A, Sport Appearance, FX4, Tow Package,
IT Specialist - CA Dept of Transportation
Noticed today, at least in my truck, that the steering wheel does rumble a little with both Alert and Aid turned on. '19 XLT, FX4. And, yes, it rumbled when the correction couldn't kick in. I moved across the center stripes as there were some bicyclists on the road.
MannyS
MannyS
Manny
Winder
Do you have aid set to highest most aggressive setting?
I have mine set to the highest setting and only notice a slight rumble. I never use it around town because i've had way to many problems with it not picking up lane changes and I found myself fighting it. I like it on longer highway trips as it helps you if you're feeling fatigued and start to cross the lines.
Dick Richie
Richard
Houston
2019 XLT Ranger
Road construction in Houston is never-ending. The first few times it activated I thought my tires had become unbalanced, or I was hitting rumble strips. I disabled mine months ago. The back up sensors detecting moving traffic and the blind spot activation get put to use frequently. You've got to constantly scan conditions ahead and be prepared for anything to happen around here. I have used it on road trips to combat lane drifting. It's definitely not for me in town.
Matsterious
Matt
Houston, TX
2022 Ford Bronco Big Bend 2.7L Mid Package 4.27
Does the blind spot monitoring make a noise or is it just the light on the side mirror?
Jon Olivier
Jon
Bishop, CA
Dick Richie
Richard
Houston
2019 XLT Ranger
I get a beeping along with the indicator light on the activated mirror. It has saved me a few times from people traveling at NASCAR speeds making lane changes in traffic while I was attempting to do the same.
Matsterious
Matt
Houston, TX
I figured it was supposed to make noise. I drilled down into the settings and didn't see where it said anything about turning on the noise. I guess I'll look in the manual now since I know it is supposed to beep.
The cross traffic alert (which is different than the blind spot monitor) makes noise. I don't believe the blind spot monitor (BLISS) makes any beeping - just the light.
Dick Richie
Richard
Houston
2019 XLT Ranger
This isn't the first time I've been wrong on the internet. Certainly not the last. Perhaps I'm confusing it with the crash warning beeping which is also activates frequently in my truck. Gotta love Houston traffic.
Matsterious
Matt
Houston, TX
I figured it would beep cause it's not a lot of helping being a small light. My old car beeped and it was super helpful.
