Labor Shop Time for Shock/Strut Installation on 2019 4x4 Lariat
Progeny2021
Charlotte, NC
  • Thread starter
  • Banned
  • #1
This morning, I dropped Ranger off at the shop I often use. His only experience with the T5 Rangers is with mine so far. This was brand new to him - wondering what normal shop hours should be, including alignment. Thanks.
If he’s a decent mechanic and it’s his first time I figure 2.5 hours. His hourly rate is what I can only guess at as well. So let’s say $300 for labor
Progeny2021
Charlotte, NC
  • Thread starter
  • Banned
  • #3
Hoping you're right but he's already stated 6 hours minimum plus alignment. Currently reading other threads here on 5g about this very subject. Prices from ridiculously cheap to ridiculously expensive - prices usually include lift/leveling.
paval3
Val
Pennsylvania
2021 Ranger XLT Crewcab & 2003 Mountaineer Premier
When I had the stock rear shocks replaced with Eibachs (which I had bought online) at a small shop down the road from where I work, it only took a few minutes so he charged me $25.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
If you are having the struts replaced with something like a bilstein that requires swapping of the springs I would use 4hrs as a good average. Plus alignment, actual numbers will vary per area and shop rates.
Ranger X3
Matthew
Sedona AZ
2019 Ranger Supercab Lariat FX4
My install was quoted $100 each for the fronts, $35 each for the rears, $70 for the alignment - OTD $347.
RangerPNW
Thomas
Santa Fe, NM
I was quoted by several people around 300-400 just for install of the fronts, not including alignment...i opted to do them myself.
Joeiconic
Did they give you a quote for the work? I always try to avoid having to go back to the shop after the work is done and say, “so what do I owe you?”. I learned that lesson the hard way many years ago :confused:
In my location, front and rears with an alignment was about $450, as I recall. I had to go to a tire shop for the alignment.
Progeny2021
Charlotte, NC
  • Thread starter
  • Banned
  • #9
Picked up Ranger a short while ago, now at home. It's almost like driving a completely different mid size truck - noticeably better! Ranger just feels different, in a very good way. Here is the final breakdown:
Bilstein 4600 rear shocks - front struts: $390
Labor: $588
4 Wheel Alignment: $90
Labor Discount: -$83
Total: $985
Note: Seeking a refund of $180 from S&D Truck Springs for the non receipt of the prepaid Bilsten rear shocks - back ordered from November. I ended up buying replacements from Summit Racing last week - received Saturday 3/19. Wishing I had dealt with Summit the first time.
This basic modification is HIGHLY recommended - well worth the money IMO. Why Ford didn't put decent shocks on Ranger from the factory is incomprehensible.
JTippin
NJ
2022 Ford Ranger XLT
Carpenter
I just last week had my BDS leveling kit installed and an alignment. $554 out the door.
VelocityBlueRanger
Tasha
Alaska
Safety Coordinator
Was just quoted for a Bilstein 5100 install and alignment from an off road specialty shop.
2 hours for all 4 shocks, $150/hr, alignment $150. I was figuring closer to 4 hours labor. Guess I'll believe it when I see it..
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
My guess is they call half way through and say they made a mistake, but my fingers are crossed for you!
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
Mine was $750 with four new tires mount/balance/alignment. The whole front end has to come apart. The back you can do yourself.
Agree with S3 above they're gonna call and say it's a bigger job than we thought.
Whiplash
Kern
The southwest Missouri Ozarks
2021 Ranger XLT FX4 / 2004 Mazda RX8
It would depend on method they use.
If they do the disconnect LCA from the frame it only takes 1/4 of the time. A total of 7 bolts . 2 bolts for the LCA to strut, 2 for LCA to frame, one for tie rod end to spindle , and 3 for the coilover top hat to frame...I have done it both ways....the disconnect everything to get the spindle out of the way is a total pain in the ass and risks CV end bearing disconnect and damage...
Progeny2021
Charlotte, NC
If they do the disconnect LCA from the frame it only takes 1/4 of the time a total of 7 bolts . 2 bolts for the LCA to strut, 2 for LCA to frame, one for tie rod end to spindle , and 3 for the coilover top hat to frame...I have done it both ways....the disconnect everything to get the spindle out of the way is a total pain in the ass and risks CV end bearing disconnect and damage...
I will be paying extra attention to my installation then. Good so far....
