"Knocking" noise on front passenger side
QCRanger48
Connor
Queen Creek, az
Went offroading over the weekend and I noticed the front end making a knocking noise on the front passenger side when going over bumps. It rides very smooth otherwise and I don't notice a rattle in the steering or anything. I did some fairly intense offroading that included some big steps up and down. I'm fairly handy but my knowledge is a little lacking. I'll be jacking it up this afternoon to take a look at everything, basically just going to try and recreate a bump and see if I can see what has come lose or what is hitting. If anyone has any ideas of what to look at first, let me know!
JasonTremor
2021 Ranger Tremor XLT
May sound odd, but is your windshield washer reservoir full? If not, fill it all the way to the top and see if the noise goes away.
If mine is not completely full, it makes what sound like knocking noises on bumps as the washer fluid sloshes in the reservoir.
QCRanger48
Connor
Queen Creek, az
Interesting! I already suspect mine is getting empty and actually bought a new jug of fluid yesterday. I'll top it off and see if that works.
I will confirm that it does make a knocking noise, if you stand at right front fender and bounce truck, you will hear it. (Mine came from factory low) Thank you Ford. I found it by shaking truck and mechanics stethoscope.
Another possible is passenger seatbelt bouncing against pillar, if not perfectly placed it rattles against pillar.
QCRanger48
Connor
Queen Creek, az
Unfortunately it was not as simple as adding wiper fluid, I topped it off and the noise is still there. Didn't get a chance to take a better look at everything, hopefully tomorrow or Thursday.
Bob902
St. Louis
RETIRED!!!!
My smart ass comment is answer the door.
Honestly its probably a sway bar end link. What you described is that to a T.
Agreed. I would start with the upper sway bar link as well.
QCRanger48
Connor
Queen Creek, az
I'll start there! Thanks guys. Looks like an easy enough fix too, fingers crossed!
Bob902
St. Louis
RETIRED!!!!
You will need an Allen wrench. Sorry I don't remember the size. An offset 18mm wrench makes life real easy. If you don't use the Allen wrench, the bolt will spin while you try to tighten the bolt.
Dereku
Chicagoland Area
Downside of a ball joint end link. But the ride quality is almost worth it. Harbor freight has a great price on offset wrenches. Bought them a few years ago to do struts and I use them more often than I ever thought I would.
QCRanger48
Connor
Queen Creek, az
Finally had some time to kill in the garage and it was the sway bar link. Tightened it up and went for a drive and problem solved. Thanks for the diagnosis!
Dereku
Chicagoland Area
No problem. I have had so many go bad over the years and I describe it just like you did.
