Key fob replacement
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Retired OTR Diver/Maintenance Mechanic
Best and easiest fob and key replacement. I lost one and would like to get two more. Location Crystal River,Fl.
I have codes and one working fob?
RangerBill
PA
You need two keys to program a new one. Since you only have one, you will need a locksmith or Ford dealer to program a second key.
k1w1t1m
Tim
Bull Shoals, AR
2021 Ford Ranger XLT FX4 SCREW
Easiest is probably go to the dealer and buy a fob, cutting, and programming. It cost me about $300 about 6 months ago. You will need proof of ownership.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Yep, a dealer is probably your best bet. Many locksmiths no longer do automotive keys here.
Craig
Craig
SLC
Buy an extra key at amazon then go to a locksmith and have it cut and programed, less expensive
hookem57
Don
Fort Worth
2021 Ranger Tremor
Driver
I had to get in for my Lariat. Ford charged me $200 for the fob and $100 to laser cut the key and reprogram both fobs.
CP0861
C
Maryland
2022 Ranger Lariat Supercrew
Old Red Replacement
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Locksmith coming provide key cut & program $250.
I tried ACE and they did not have it in stock, and he did not offer price to cut and program, it maybe cheaper option.
Don’t put key and her purse in garbage dumpster by mistake h@ campground and not realize it till waste management picked it up and dumped it at transfer station.
I went there and they were no help?
pboggini
Pete
San Jose, CA
2019 Lightning Blue XL Ranger 4x2 Supercrew.
I went here to get an OEM replacement:
https://northcoastkeyless.com/
Thought I'd be able to program it since I have two original keys. Alas, I could not. Tried the various procedures I saw online, talked to a friend at Folsom Lake Ford who confirmed the process and it didn't work. Had to pay a roaming locksmith $100 to program it. When he connected his device to my OBD2 port, it reported that I did indeed have two keys and the new key programmed in seconds so I was pretty bummed that I couldn't do it myself.
Then again, it cost me $59.94 total for the fob, Outdoor Supply Hardware (the revival of Orchard Supply Hardware) cut it for free (because he said he could only program keys purchased there) and then the $100 for programming so I guess it's not that bad. Then again, I'm cheap so it still annoys me.
seanellaz
Sean
Tucson, AZ
Healthcare
byronmaysko
byro
Los Angeles
Land Cruiser
Driver
I had a similar situation and ended up calling the crew I found through https://royallocksmithfl.com/ because they handle everything from quick lock fixes to full replacements. Their tech showed up fast, didn’t overcharge, and even helped me figure out a better security setup. If you need someone reliable on short notice, they made the whole thing a lot less stressful for me.
