outdoorphotog
- First Name
- Ian
- Joined
- Dec 15, 2019
- Threads
- 21
- Messages
- 814
- Reaction score
- 2,585
- Location
- Healdsburg, CA
- Vehicle(s)
- 2019 Lincoln Navigator L
- Occupation
- Limo Driver
- Thread starter
- #1
Today I installed the PPE cast aluminum extended capacity transmission pan. Its a very nice high quality peice and I look forward to having the drain plug. I took my pneumatic brake bleeder and sucked out 5.75 ish quarts, then removed the stock pan. Ended up putting in a little under 8 quarts to get the dipstick back to the correct level. When i initially checked the dipstick it was at (3) when the engine was cold so i tried to fill it back to that exact spot. Also installed the B&M trans dipstick, woah are they proud of that at $200 for a couple fittings and a piece of hose. Made marks on the B&M dipstick with a knife to matchup the numbers (3), (4) and (5). I was surpised by how dark brown the ATF was after only 21k miles, so was glad to add the new fluid. I should have done the trans filter, but I didnt have one, ill install it around 40k or 50k miles.
